shp2img fails with layer REQUIRES
Tim Schaub
tim at COMMENSPACE.ORG
Mon Sep 12 13:50:23 EDT 2005
Hello-
I'm trying to use the REQUIRES layer attribute and having no luck.
Everything works as expected when I have a mapfile with 1 REQUIRES
attribute. Adding a second layer with REQUIRES doesn't work.
I'm guessing that this is what
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1283 is about. If
not, here are the details of my problem:
Using
MapServer version 4.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF O
UTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIEN
T SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=JPEG
INPUT=P
OSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
and the mapfile pasted here
(http://rafb.net/paste/results/QpsrsQ14.html)
<http://rafb.net/paste/results/QpsrsQ14.html)below> , shp2img works if I
comment out one of the REQUIRES lines and fails silently if I leave both
uncommented.
Thanks for any hints,
Tim
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050912/8b636ccf/attachment.html
