SLD PIXMAP Error With How-To Example
Jennifer Zeisloft jzeisloft at GMAIL.COM
Mon Sep 12 23:52:06 EDT 2005
Hello-
I have an update for this problem with using external graphics for SLD
requests.
I attempted to use the SLD file at
http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_polygon_fill_symbol_external.xml
with the ms4w-Chameleon OGC sample application (which contains the proper
layer - WorldGen- for the SLD) and received the same error messages that
I've been receiving with my own application:
*Warning*: [MapServer Error]: loadSymbol(): Symbol of type PIXMAP has no
image data. in *C:\ms4w\apps\chameleon\htdocs\common\wrapper\map_session.php
* on line *215*
*Warning*: Failed to open map file /ms4w/tmp/sess_43264a06bd7bc/1126582974-
2202.map in *C:\ms4w\apps\chameleon\htdocs\common\wrapper\map_session.php*on
line
*215*
*Fatal error*: Call to a member function on a non-object in *
C:\ms4w\apps\chameleon\htdocs\widgets\KeyMapDHTML\KeyMapDHTML.widget.php* on
line *150*
Could this be a bug?? Could there be a problem with the way ms4w is set up
on our server (although we did nothing different this time...)? Is there a
copy of this same sample application available through the MapServer website
so that I could test the same application on a different server (if so, I
haven't been able to find it)? This is a problem I just haven't made any
headway on and any suggestions would be greatly appreciated!
Jennifer Zeisloft
UW Sea Grant
On 9/8/05, Jennifer Zeisloft <jzeisloft at gmail.com> wrote:
> Hi-
> I have created a temporary directory with all of the associated files: the
> context file, the sld file, the temp map file, the temp image file, and the
> wms map file.
> https://mywebspace.wisc.edu/jrzeisloft/web/temp/
> I don't know that you'll need all of those, but I'm not really sure where
> the problem is. Other (non-external) SLDs can be applied without a problem.
> The application I am working on is located at
> http://maps.aqua.wisc.edu/lscmp/viewmaps.phtml. The context I was using to
> test the external graphic SLD is the Bluff Stability context. The layer I
> was using is the Bluff Profiles layer. The SLD I was trying to open is at
> https://mywebspace.wisc.edu/jrzeisloft/web/temp/sld_symbol_external.xml.
> I can't think of any other information to offer: I simply go to the
> application, open the bluff stability context, select the bluff profile
> layer (though I am not sure this is necessary), click the Open SLD tool
> button, and browse to the SLD file. Then the error occurs.
> Thanks for your help!
> Jennifer Zeisloft
> On 9/8/05, Yewondwossen Assefa <assefa at dmsolutions.ca> wrote:
> > Not sure what the initial error is but you could check the map file
> > 1126209374-4254.map and see if the inline symbols created reference an
> > existing png or gif file.
> > I would also be nice if you could provide a quick was (+ all realted
> > files) to reproduce this bug. At this point I am not sure how to
> > reproduce it.
> > Later,
> > Jennifer Zeisloft wrote:
> > > Hello All-
> > > I am starting to play with SLD and am attempting to use an external
> > > graphic to symbolize a point. I first tried it with my own external
> > > graphic, but got the error message:
> > no
> > > image data. in
> > > *C:\ms4w\apps\chameleon\htdocs\common\wrapper\map_session.php* on line
> > *215*
> > > /ms4w/tmp/sess_4320970788d61/1126209374-4254.map in
> > *215*
> > *C:\ms4w\apps\chameleon\htdocs\widgets\KeyMapDHTML\KeyMapDHTML.widget.php*
> > > on line *150*
> > > I then tried it with the sld_symbols_external.xml file from the SLD
> > > How-To document (I changed the layer name, of course) and received the
> > > same error. I also tried using PNG instead of GIF - same error. Can
> > > anyone offer a hint? Thanks in advance for your help!
> > > Jennifer Zeisloft
> > > UW Sea Grant
> > Assefa Yewondwossen
> > Software Analyst
> > Email: assefa at dmsolutions.ca
> > http://www.dmsolutions.ca/
> > Phone: (613) 565-5056 (ext 14)
> > Fax: (613) 565-0925
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050912/36daa34e/attachment.html
