FILTER working on PostGIS layers?
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Tue Sep 13 07:26:44 EDT 2005
Hi list,
I am running into an issue using Mapscript 4.7 from a few weeks back.
PostGIS layers work fine for map display and query, but as soon as I try to highlight a feature using FILTERITEM and FILTER I get the following error (so it seems the filteritem is not used when building the WHERE clause, the column exists in the database and has the right case):
[13-Sep-2005 13:06:43] PHP Warning: [MapServer Error]: prepare_database(): Error executing POSTGIS DECLARE (the actual query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT identbv::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text from bouwvergunning.aanvraag WHERE (20050049) and (the_geom && setSRID( 'BOX3D(114024.650480941 503134.482620259,115117.267932596 503806.862590517)'::BOX3D,find_srid('','bouwvergunning.aanvraag','the_geom') ))' <br><br>
Postgresql reports the error as 'ERROR: argument of AND must be type boolean, not type integer ........
This is my LAYER definition:
LAYER
NAME "bimas"
METADATA
wms_title "Bouwvergunningen"
END
STATUS OFF
DEBUG ON
FILTERITEM "identbv"
FILTER "20050049"
TYPE POINT
CONNECTION "user=stragisweb password=synstragisweb dbname=wormerland host=127.0.0.1"
CONNECTIONTYPE postgis
DATA "the_geom from bouwvergunning.aanvraag USING UNIQUE identbv"
PROJECTION
"init=epsg:28992"
END
MINSCALE 0
MAXSCALE 10000
CLASS
NAME bouwlocaties
STYLE
COLOR 255 0 0
SIZE 12
SYMBOL "Bouwlocaties"
END
END
TEMPLATE "blank.html"
END
Thanks in advance. Is this fixed in CVS?
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
