FILTER working on PostGIS layers?
Bart van den Eijnden BEN at SYNCERA-ITSOLUTIONS.NL
Tue Sep 13 09:45:53 EDT 2005
Follow-up on this.
It seems that layer->filter.string only contains the FILTER value and not the whole expression to be used in the where clause.
sprintf(query_string_0_6, "DECLARE mycursor BINARY CURSOR FOR SELECT %s from %s WHERE (%s) and (%s && setSRID( %s,%s) )", columns_wanted, data_source, layer->filter.string, geom_column, box3d, user_srid);
Does this sound familiar to anyone?
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG  DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Bart van den Eijnden <BEN at SYNCERA-ITSOLUTIONS.NL> 13-9-2005 13:26:44 >>>
Hi list,
I am running into an issue using Mapscript 4.7 from a few weeks back.
PostGIS layers work fine for map display and query, but as soon as I try to highlight a feature using FILTERITEM and FILTER I get the following error (so it seems the filteritem is not used when building the WHERE clause, the column exists in the database and has the right case):
[13-Sep-2005 13:06:43] PHP Warning:  [MapServer Error]: prepare_database(): Error executing POSTGIS DECLARE (the actual query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT identbv::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text from bouwvergunning.aanvraag WHERE (20050049) and (the_geom && setSRID( 'BOX3D(114024.650480941 503134.482620259,115117.267932596 503806.862590517)'::BOX3D,find_srid('','bouwvergunning.aanvraag','the_geom') ))' <br><br>
Postgresql reports the error as 'ERROR:  argument of AND must be type boolean, not type integer ........
This is my LAYER definition:
LAYER
  NAME "bimas"
  METADATA
    wms_title "Bouwvergunningen"
  END
  STATUS OFF
  DEBUG ON
  FILTERITEM "identbv"
  FILTER "20050049"
  TYPE POINT
  CONNECTION "user=stragisweb password=synstragisweb dbname=wormerland host=127.0.0.1"
  CONNECTIONTYPE postgis
  DATA "the_geom from bouwvergunning.aanvraag USING UNIQUE identbv"
  PROJECTION
    "init=epsg:28992"
  END
  MINSCALE 0
  MAXSCALE 10000
  CLASS
    NAME bouwlocaties
    STYLE
      COLOR 255 0 0
      SIZE 12
      SYMBOL "Bouwlocaties"
    END
  END
  TEMPLATE "blank.html"
END
Thanks in advance. Is this fixed in CVS?
Best regards,
Bart
Postbus 270
2600 AG  DELFT
