WFS and Oracle
Huub Fleuren
hfl at HOME.NL
Tue Sep 13 17:10:09 EDT 2005
Hi Fernando,
just now tested the following compile libcurl 7.13.2 oracle 10g / gdal
1.3 (with oracle 10g/xerces 2.4) (on a different server)
http://host/cgi-bin/testbin/mapserv.exe?map=s5.map&request=getfeature&service=wfs&typename=bommen&version=1.0.0
(the layer bommen contains 10 points)
same problem, mapserver crashes on wfs/oracle (not on wfs / shape),
getcapabilities works (very slow), describefeaturetype works
LAYER
STATUS ON
DEBUG OFF
CONNECTIONTYPE oraclespatial
CONNECTION "usr/pwd at db"
PROCESSING "CLOSE_CONNECTION=DEFER"
NAME "bommen"
DATA "geom ( select geom, id from bommen ) using unique id srid 90112"
TYPE POINT
DUMP TRUE
METADATA
"Wms_Srs" "Epsg:28992"
"Wms_Name" "bommen"
"Wms_Title" "bommen"
END
CLASS
NAME "Bommen"
STYLE
SYMBOL 'bommen'
SIZE 20
COLOR 120 120 120
END
END
END
Fernando Simon wrote:
> Hi Huub,
> I saw a little problem with your layer definition, using the layer
> definition that you sent in previously e-mail (08/24/2005) you defined
> the FILTER and FILTERITEM parameter.
> The Mapfile reference tells that the FILTERITEM parameter is only
> for shapefiles/OGR. The FILTER parameter can be defined for Oracle
> Spatial, I already saw a problem with FILTER parameter and WFS
> requests (Oracle Spatial), but I didn't find the core of the problem yet.
> Using you layer definition that you sent before you can solve this
> problem when you need to redefine your DATA parameter, as:
> "GEOMETRIE FROM (SELECT GEOMETRIE, ID FROM KBK.KBK_gebouw WHERE
> ID = 623898) USING UNIQUE ID SRID 90112" or
> ID = 623898) USING UNIQUE ID SRID 90112 NONE"
> Just to test and confirm the problem, can you sent the WFS request
> that generate the error?
> Thanks.
> Fernando Simon
> Mapserver and Oracle Spatial developer
> G10 - Laboratorio de Computacao Aplicada - Brazil
> http://www.univali.br/g10 - UNIVALI/CTTMAR
> Huub Fleuren wrote:
>> Hi
>> I've been building mapserver with a properly installed vc6sp6 since a
>> week or two
>> -oracle92
>> -libcurl 7.10.7 7.13.2 7.14.0
>> -gdal 1.2.5 1.2.6 1.3.0 (with / without oraclesupport)
>> -mapserver 4.4.1 4.6 and CVS (wfs server/client support)
>> In different combinations
>> There was not a mapserver that did not crash on a WFS request for
>> Oracle.
>> Would Howard Butler want to run his oracle92 build again with the
>> newest releases and see if it works for me?
>> Regards, Huub
