angleitem for point symbols
Jeff McKenna
jmckenna at DMSOLUTIONS.CA
Wed Sep 14 09:09:43 EDT 2005
yes, but ANGLEITEM should be specified in a STYLE object
(http://mapserver.gis.umn.edu/doc46/mapfile-reference.html#style).
jeff
Francesco Sozzi wrote:
> Hi All,
> I've found in http://dl.maptools.org/dl/mapserver_Changelog.txt a
> reference to ANGLEITEM for points (see 2005-08-05 14:45 sdlime). This
> is a good new because a rotation management for point symbols is
> strongly recommended in a map renderer.
> I've just compiled mapserver 4.6.1 and I tried to create a layer with
> this attribute, but I get a parse error.
> Anybody knows if this attribute i supported?
> This is my layer definition:
> LAYER
> NAME "Segnali"
> TYPE POINT
> CONNECTIONTYPE oraclespatial
> CONNECTION "ti_segnali/avs at franz <mailto:ti_segnali/avs at franz>"
> DATA "GEOM FROM (SELECT a.fid, g.orientation, a.geom FROM ic_segnali a,
> ic_segnali_geo g WHERE a.fid=g.fid) USING UNIQUE fid NONE"
> STATUS DEFAULT
> ANGLEITEM "orientation"
> CLASS
> NAME 'segnale'
> SYMBOL 'triangle'
> COLOR 0 255 0
> OUTLINECOLOR 183 183 183
> TEMPLATE "templates/default.html"
> END
> END
> Best regards
> Francesco
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
