angleitem for point symbols
Francesco Sozzi
fsozzi at INTERCAD.CH
Wed Sep 14 09:16:37 EDT 2005
Hi Jeff,
I've also made a test with this definition:
LAYER
NAME "Segnali"
TYPE POINT
CONNECTIONTYPE oraclespatial
CONNECTION "ti_segnali/avs at franz"
DATA "GEOM FROM (SELECT a.fid, g.orientation, a.geom FROM ic_segnali a,
ic_view_segnali_geo g WHERE a.gid=g.gid) USING UNIQUE fid NONE"
STATUS DEFAULT
CLASS
NAME 'segnale'
STYLE
SYMBOL 'triangle'
ANGLEITEM "orientation"
SIZE 10
COLOR 255 0 0
END
TEMPLATE "templates/default.html"
END
END
In this case I have not a parse error, but all triangles are not rotated. It
seems that this attribute is ignored.
Regards
Francesco
----- Original Message -----
To: "Francesco Sozzi" <fsozzi at INTERCAD.CH>
Cc: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Wednesday, September 14, 2005 3:09 PM
Subject: Re: [UMN_MAPSERVER-USERS] angleitem for point symbols
> yes, but ANGLEITEM should be specified in a STYLE object
> (http://mapserver.gis.umn.edu/doc46/mapfile-reference.html#style).
> jeff
> Francesco Sozzi wrote:
>> Hi All,
>> I've found in http://dl.maptools.org/dl/mapserver_Changelog.txt a
>> reference to ANGLEITEM for points (see 2005-08-05 14:45 sdlime). This is
>> a good new because a rotation management for point symbols is strongly
>> recommended in a map renderer.
>> I've just compiled mapserver 4.6.1 and I tried to create a layer with
>> this attribute, but I get a parse error.
>> Anybody knows if this attribute i supported?
>> This is my layer definition:
>> LAYER
>> NAME "Segnali"
>> TYPE POINT
>> CONNECTION "ti_segnali/avs at franz <mailto:ti_segnali/avs at franz>"
>> ic_segnali_geo g WHERE a.fid=g.fid) USING UNIQUE fid NONE"
>> STATUS DEFAULT
>> CLASS
>> NAME 'segnale'
>> SYMBOL 'triangle'
>> COLOR 0 255 0
>> OUTLINECOLOR 183 183 183
>> END
>> END
>> Best regards
>> Francesco
> Jeff McKenna
> DM Solutions Group Inc.
> http://www.dmsolutions.ca
