angleitem for point symbols
Jeff McKenna jmckenna at DMSOLUTIONS.CA
Wed Sep 14 09:43:56 EDT 2005
Sorry Francesco, I just tested again and it doesn't work for me either.
  I remember adding it to the documentation, for this bug
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=815.  I just now got
ANGLEITEM to work with a hatched symbol again, but for a regular point
symbol it does not work.  I should update the doc to say that it is only
for hatched symbols...maybe someone else has info on this?
jeff
Francesco Sozzi wrote:
> Hi Jeff,
> I've also made a test with this definition:
> LAYER
> NAME "Segnali"
> TYPE POINT
> CONNECTIONTYPE oraclespatial
> CONNECTION "ti_segnali/avs at franz"
> DATA "GEOM FROM (SELECT a.fid, g.orientation, a.geom FROM ic_segnali a,
> ic_view_segnali_geo  g WHERE a.gid=g.gid) USING UNIQUE fid NONE"
> STATUS DEFAULT
> CLASS
>  NAME 'segnale'
>  STYLE
>   SYMBOL 'triangle'
>   ANGLEITEM "orientation"
>   SIZE 10
>   COLOR 255 0 0
>  END
>  TEMPLATE "templates/default.html"
> END
> END
> In this case I have not a parse error, but all triangles are not
> rotated. It seems that this attribute is ignored.
> Regards
> Francesco
> ----- Original Message ----- From: "Jeff McKenna" <jmckenna at dmsolutions.ca>
> To: "Francesco Sozzi" <fsozzi at INTERCAD.CH>
> Cc: <MAPSERVER-USERS at LISTS.UMN.EDU>
> Sent: Wednesday, September 14, 2005 3:09 PM
> Subject: Re: [UMN_MAPSERVER-USERS] angleitem for point symbols
>> yes, but ANGLEITEM should be specified in a STYLE object
>> (http://mapserver.gis.umn.edu/doc46/mapfile-reference.html#style).
>> jeff
>>> Hi All,
>>>  I've found in http://dl.maptools.org/dl/mapserver_Changelog.txt a
>>> reference to ANGLEITEM for points (see 2005-08-05 14:45  sdlime).
>>> This is a good new because a rotation management for point symbols is
>>> strongly recommended in a map renderer.
>>>  I've just compiled mapserver 4.6.1 and I tried to create a layer
>>> with this attribute, but I get a parse error.
>>>  Anybody knows if this attribute i supported?
>>>  This is my layer definition:
>>>  LAYER
>>>  NAME "Segnali"
>>>  TYPE POINT
>>>  CONNECTION "ti_segnali/avs at franz <mailto:ti_segnali/avs at franz>"
>>> a, ic_segnali_geo g WHERE a.fid=g.fid) USING UNIQUE fid NONE"
>>>  STATUS DEFAULT
>>>  CLASS
>>>   NAME 'segnale'
>>>   SYMBOL 'triangle'
>>>   COLOR 0 255 0
>>>   OUTLINECOLOR 183 183 183
>>>  END
>>> END
>>>  Best regards
>>>  Francesco
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
