GTiff outputformat
Lluís Garcia i Mestres
lluisgm at GMAIL.COM
Thu Sep 15 04:30:37 EDT 2005
Hi Frank,
Using the gdal_translate I'm getting an error about the gdall12 library.
I've tried the same operation with the FWtools package and I'm getting a
valid tiff, so the problem is the ms4w_1.2.1 package and it's why I'm not
seeing the maps in my mapserver application. The spelling in my mapfile was
correct, now I need to solve this error in the gdal library in order to get
geotiff images in my mapserver application.
Thanks for all
2005/9/14, Frank Warmerdam <fwarmerdam at gmail.com>:
> On 9/14/05, Lluís Garcia i Mestres <lluisgm at gmail.com> wrote:
> > Hi Frank,
> > My gtiff file is readable by gdalinfo, and is still working in mozilla
> and
> > ie throught the quicktime pluging but not with other programs even with
> > interleave=pixel line . If I export to autocad, I'm getting the image
> with
> > very low quality, almost none.
> > I don't understand why geotiff image are not readable even for the
> windows
> > explorer. Should I need a plugin for windows?
> Lluis,
> I have reviewed the file you sent, and confirmed that it is still planar
> configuration separate. If I do:
> gdal_translate -co INTERLEAVE=PIXEL in.tif out.tif
> It becomes previewable in windows explorer.
> Please review that you spelled everything correctly in your
> outputformat declaration, that it is actually getting used and so forth.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
Lluís Garcia i Mestres,
lluisgm at hotmail.com
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050915/d28dd7ea/attachment.html
