Units problem
Miguel Gonçalves
mgoncalves at DSI.UMINHO.PT
Thu Sep 15 05:01:30 EDT 2005
Hi Yewondwossen,
I tried what you said but stills not worling.
Can I send the data files and the map object to your personal mail?
Thanks.
Best regards.
Miguel
Yewondwossen Assefa wrote:
> Hi There,
> Normally the unit should be parsed from the filter and set as the
> value of the toleranceunits and your distance should be used to update
> the tolerance of the layer.
> The only thing that might be missing (assuming that all filter
> encoding is parsed properly) is that you should set the units of your
> map file to degrees (at the map level set UNITS "dd"). If that does
> not solve your issue please sned me a simple map file/data/and the
> filter encoding and I will test it here.
> Later,
> Miguel Gonçalves wrote:
>> Hello list,
>> I am using mapserver 4.6 for windows
>> I am using the following DWidth request
>> http://localhost/cgi-bin/mapserv.exe?VERSION=1.0.0&SERVICE=WFS&REQUEST=GetFeature&TYPENAME=cities&MAP=../MAPS/tutorial/europe_1.map&Filter=
>> <Filter>
>> <DWithin>
>> <PropertyName>Geometry</PropertyName>
>> <gml:Point>
>> <gml:coordinates>-8.418000,41.539600</gml:coordinates>
>> </gml:Point>
>> <Distance units='m'>1000</Distance>
>> </DWithin>
>> </Filter>
>> and I am having some problems with the units.
>> I specified units='m' but, in the results that I obtain, the distance
>> between the geographical features is in degrees (I checked with ArcMap).
>> Can you help me to solve this problem?
>> Thanks.
>> Best regards.
>> Miguel
>> P.S. If it helps, here is my map object
>> MAP
>> EXTENT -36.133725 5.7104918367 66.0633 71.1839
>> SHAPEPATH "europe_1_data"
>> WEB
>> METADATA
>> WFS_TITLE "Mapa da Europa"
>> WFS_SRS "http://localhost/cgi-bin/mapserv.exe?"
>> END
>> END
>> ############## LAYER cities
>> LAYER
>> NAME cities
>> DATA cities
>> TYPE line
>> DUMP TRUE TOLERANCEUNITS
>> METERS
>> METADATA
>> WFS_TITLE "cities layer"
>> GML_INCLUDE_ITEMS "all"
>> END
>> END
>> ############## LAYER mjroads
>> LAYER
>> NAME mjroads
>> DATA mjroads
>> TYPE line
>> DUMP TRUE
>> TOLERANCEUNITS METERS
>> METADATA
>> WFS_TITLE "mjroads layer"
>> END
>> END
>> ##############LAYER country
>> LAYER
>> NAME countries
>> DATA countries
>> TYPE polygon
>> DUMP TRUE
>> METADATA
>> WFS_TITLE "country layer"
>> END
>> END
>> END
