Perl Mapscript Problem
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Fri Sep 16 00:12:12 EDT 2005
Stephen Woodbridge wrote:
> Hi All,
> I had dynamic symbol manipulation working on MS 4.01 but can not get it
> to work on 4.4.1 or 4.6.1. In the following code snippets every think
> works with the default symbol that is defined in symbolset file, but the
> code does not let me change the imagepath on the fly.
> Also, I can not get the label on the umarker layer to show unless I
> specify LABELCACHE FALSE and umarker layer is the last in the
> mapfile.
> Any ideas or help would be appreciated.
> -Steve W.
> From the mapscript:
> my $lay = $mapObj->getLayerByName('umarker');
> if ($lay) {
> $lay->{status} = 1;
> my $class = $lay->getClass(0);
> my $pnt = new mapscript::pointObj();
> my @marks = split(/;/, $mark);
> foreach my $x (@marks) {
> my ($y, $x, $txt, $sym) = split(/[\s,]/, $x);
> if ($sym && -r "$symbol_path/$sym") {
> my $style = $class->getStyle(0);
> $style->{symbolname} = "$symbol_path/$sym";
> $pnt->{x} = $x;
> $pnt->{y} = $y;
> $pnt->draw($mapObj, $lay, $imgObj, 0, $txt);
> Or alternately from mapscript:
> if ($lay) {
> $lay->{status} = 1;
> my $symbolset = $mapObj->{symbolset};
> my $symbol = $symbolset->getSymbolByName('marker');
> $symbol->{imagepath} = "$symbol_path/$sym";
> $pnt->{x} = $x;
> $pnt->{y} = $y;
> From the mapfile:
> LAYER
> NAME "umarker"
> STATUS ON
> TYPE POINT
> LABELCACHE FALSE
> TEMPLATE "ttt.html"
> CLASS
> NAME "User Marker"
> #TEXT "HERE"
> SYMBOL "marker"
> COLOR 0 0 0
> LABEL
> TYPE TRUETYPE
> FONT "arial-bold"
> SIZE 8
> POSITION AUTO
> OFFSET 0 0
> BUFFER 4
> COLOR 0 0 0
> OUTLINECOLOR 230 230 230
> FORCE TRUE
> END
> END
> END
> From the symbol.sym symbolset file:
> Symbol
> Name 'marker'
> Type PIXMAP
> Image 'markers/purppin.png'
> Transparent 1
> END
Here is yet another variation that does not work:
# draw markers on the image
if ($lay) {
$lay->{status} = 1;
my @marks = split(/;/, param('mark') || $mark);
my $tmp_sym = new mapscript::symbolObj('tmp_sym',
"$symbol_path/$sym");
my $tmp_img = $tmp_sym->getImage($mapscript::MS_PNG);
$symbol->setImage($tmp_img);
$pnt->{x} = $x;
$pnt->{y} = $y;
I also explicitly added a STYLE block to the mapfile like:
LAYER
NAME "umarker"
STATUS ON
TYPE POINT
LABELCACHE FALSE
TEMPLATE "ttt.html"
CLASS
NAME "User Marker"
STYLE
SYMBOL "marker"
COLOR 0 0 0
END
#TEXT "HERE"
LABEL
TYPE TRUETYPE
FONT "arial-bold"
SIZE 8
POSITION AUTO
OFFSET 0 0
BUFFER 4
COLOR 0 0 0
FORCE TRUE
END
END
END
