Mapserver and threading
Shawn Wallbridge shawn at SYNACK-HOSTING.COM
Sun Sep 18 00:17:45 EDT 2005
On 17-Sep-05, at 10:00 PM, Frank Warmerdam wrote:
> On 9/17/05, Shawn Wallbridge <shawn at synack-hosting.com> wrote:
>> I am contemplating the machine I want to run Mapserver on and I am
>> trying to decide between a a couple of machines.
>> Has anyone run Mapserver on a 4+ CPU machine? Does it thread very
>> well?
>> PostGIS will be running on a different machine (Quad Processor Sun
>> e450 with 4GB of Ram, lots of SCSI disks running Solaris 10).
> Shawn,
> The common way of running MapServer is as a cgi (either mapserv
> itself, or a mapscript cgi).  In this form, each cgi request will
> run on
> a single CPU but several requests can be effectively serviced at a
> time.
> It is also possible to run MapServer in a multi-threaded way.  I
> would have to say that this is not so widely used, and consequently
> somewhat risky.
> So, if you are running as a cgi, then you will be able to support more
> requests on a multi-cpu system than on a single cpu system assuming
> you find things are cpu bound.  Of course, in many cases things are
> really input/output or memory bound in which case the multi-cpus will
> give relatively little benefit.
> Best regards,
Thanks, I guess I wasn't thinking, because I _should_ have known
that ;-)
So the 14 Processor Sun E4000 it is ;-)
shawn
