WFS and Oracle
Huub Fleuren
hfl at HOME.NL
Mon Sep 19 04:36:57 EDT 2005
Hello,
If you use Mapserver 4.6 and later for wfs requests on Oracle Spatal layers do not use the 'normal' synstax of
DATA "GEOMETRIE FROM GEBOUW USING UNIQUE ID SRID 90112"
This helps Mapserver very much to crash
Instead use the other syntax that works for joins as the datasource
DATA "GEOMETRIE FROM (SELECT GEOMETRIE, ID FROM GEBOUW ) USING UNIQUE ID SRID 90112"
This has been tested on database versions 10g and 9.2
I suppose the suggestion to compile on windows with MSVC service pack 4 5 or 6 holds, i didn't go back on that.
Regards,
Huub
