angleitem for point symbols
Brock Anderson
banders at REFRACTIONS.NET
Mon Sep 19 13:12:50 EDT 2005
I am also interested in rotating point symbols, especially vector
symbols. Is there currently an effort to add support for point symbol
rotation? I see this bug:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=533
hasn't been updated in over a year. As I understand it, it's currently
impossible to rotate point symbols via both STYLE -> ANGLE , and STYLE
-> ANGLEITEM. Is that correct?
Brock
Jeff McKenna wrote:
> Sorry Francesco, I just tested again and it doesn't work for me
> either. I remember adding it to the documentation, for this bug
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=815. I just now got
> ANGLEITEM to work with a hatched symbol again, but for a regular point
> symbol it does not work. I should update the doc to say that it is
> only for hatched symbols...maybe someone else has info on this?
> jeff
> Francesco Sozzi wrote:
>> Hi Jeff,
>> I've also made a test with this definition:
>> LAYER
>> NAME "Segnali"
>> TYPE POINT
>> CONNECTIONTYPE oraclespatial
>> CONNECTION "ti_segnali/avs at franz"
>> DATA "GEOM FROM (SELECT a.fid, g.orientation, a.geom FROM ic_segnali
>> a, ic_view_segnali_geo g WHERE a.gid=g.gid) USING UNIQUE fid NONE"
>> STATUS DEFAULT
>> CLASS
>> NAME 'segnale'
>> STYLE
>> SYMBOL 'triangle'
>> ANGLEITEM "orientation"
>> SIZE 10
>> COLOR 255 0 0
>> END
>> TEMPLATE "templates/default.html"
>> END
>> END
>> In this case I have not a parse error, but all triangles are not
>> rotated. It seems that this attribute is ignored.
>> Regards
>> Francesco
>> ----- Original Message ----- From: "Jeff McKenna"
>> <jmckenna at dmsolutions.ca>
>> To: "Francesco Sozzi" <fsozzi at INTERCAD.CH>
>> Cc: <MAPSERVER-USERS at LISTS.UMN.EDU>
>> Sent: Wednesday, September 14, 2005 3:09 PM
>> Subject: Re: [UMN_MAPSERVER-USERS] angleitem for point symbols
>>> yes, but ANGLEITEM should be specified in a STYLE object
>>> (http://mapserver.gis.umn.edu/doc46/mapfile-reference.html#style).
>>> jeff
>>>> Hi All,
>>>> I've found in http://dl.maptools.org/dl/mapserver_Changelog.txt a
>>>> reference to ANGLEITEM for points (see 2005-08-05 14:45 sdlime).
>>>> This is a good new because a rotation management for point symbols
>>>> is strongly recommended in a map renderer.
>>>> I've just compiled mapserver 4.6.1 and I tried to create a layer
>>>> with this attribute, but I get a parse error.
>>>> Anybody knows if this attribute i supported?
>>>> This is my layer definition:
>>>> LAYER
>>>> NAME "Segnali"
>>>> TYPE POINT
>>>> CONNECTION "ti_segnali/avs at franz <mailto:ti_segnali/avs at franz>"
>>>> ic_segnali a, ic_segnali_geo g WHERE a.fid=g.fid) USING UNIQUE fid
>>>> NONE"
>>>> STATUS DEFAULT
>>>> CLASS
>>>> NAME 'segnale'
>>>> SYMBOL 'triangle'
>>>> COLOR 0 255 0
>>>> OUTLINECOLOR 183 183 183
>>>> END
>>>> END
>>>> Best regards
>>>> Francesco
