mapserver-postgis centroid function
Obe, Regina DND\MIS
robe.dnd at CITYOFBOSTON.GOV
Tue Sep 20 17:27:45 EDT 2005
I think the problem may be your * at the end because that would add in your
regular the_geom so you would end up having 2 the_geom fields. try getting
rid of * and explicitly listing the fields you need.
-----Original Message-----
Sent: Tuesday, September 20, 2005 5:20 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] mapserver-postgis centroid function
Hi all,
I am trying to get the centroid of the parcels using postgis to get the
centroid of each parcel. I have pasted the layer definition below.
LAYER
NAME "Calhoun_Parcel_centroid"
GROUP "Calhoun County Data"
STATUS OFF
DATA "the_geom FROM (select centroid(the_geom) AS the_geom,* from
cal_parcel) AS foo USING UNIQUE gid USING SRID=26929"
TYPE POINT
CONNECTIONTYPE POSTGIS
CONNECTION "user=parcel password=dbpass dbname=AnnistonDB host=localhost
port=5432"
UNITS METERS
SIZEUNITS PIXELS
LABELCACHE ON
LABELITEM "PPIN"
LABELMAXSCALE 6000
TOLERANCE 0
TOLERANCEUNITS PIXELS
TEMPLATE "ttt_query"
METADATA
"layer_title" "Selected Parcel"
END
CLASS
NAME "Selected Parcel"
LABEL
TYPE TRUETYPE
FONT "fritqat"
SIZE 8
MINSIZE 4
MAXSIZE 256
POSITION CC
OFFSET 0 0
ANGLE AUTO
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 0 0 0
OUTLINECOLOR 200 200 200
ANTIALIAS TRUE
PARTIALS TRUE
FORCE FALSE
END
STYLE
SYMBOL 3
COLOR 200 0 200
SIZE 10
END
END
END
I am getting this warning if I try to use this layer
Warning: [MapServer Error]: msDrawMap(): Failed to draw layer named
'Calhoun_Parcel_centroid'. in C:\ms4w\Apache\htdocs\Anniston11\Develop2.php
on line 82
Warning: [MapServer Error]: prepare_database(): Error executing POSTGIS
DECLARE (the actual query) statement: 'DECLARE mycursor BINARY CURSOR FOR
SELECT asbinary(force_collection(force_2d(the_geom)),'NDR'),gid::text from
(select centroid(the_geom) AS the_geom,* from cal_parcel) AS foo WHERE
the_geom && setSRID('BOX3D(626801.874849 1124507.96601,683350.291609
1166919.27858)'::BOX3D, -1 )'
Postgresql reports the error as 'ERROR: column reference "the_geom" is
ambiguous '
More Help:
Error with POSTGIS data variable. You specified '<check your .map file>'.
Standard ways of specifiying are :
(1) 'geometry_column from geometry_table'
(2) 'geometry_column from (<sub query>) as foo using unique <column name>
using SRID=<srid#>'
Make sure you put in the 'using unique <column name>' and 'using SRID=#'
clauses in.
I found that I was losing the SRID information when I tried to use the
centroid function in postgis. I have pasted my output below. I was wondering
if anyone can help me fix this error. Any input would be appreciated.
AnnistonDB=# select the_geom from cal_parcel where ppin = '123';
the_geom
----------------------------------------------SRID=26929;MULTIPOLYGON(((5921
29.329345788......)))
(1 row)
AnnistonDB=# select centroid(the_geom) from cal_parcel where ppin = '123';
centroid
SRID=-1;POINT(592030.853820728 1186660.20937603)
(1 row)
AnnistonDB=# select postgis_full_version();
POSTGIS="0.9.1" GEOS="2.1.4" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
DBPROC="0.0.1" RELPROC="0.0.1"
Thanks
- kumar
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050920/68032b56/attachment.html
