mapserver-postgis centroid function
Kumar
kumar at NEWFIELDS.COM
Tue Sep 20 21:53:02 EDT 2005
I got the mapfile working with
DATA "shape FROM (select centroid(the_geom) AS shape,gid,PPIN from
cal_parcel) AS foo USING UNIQUE gid USING SRID=-1
I am still wondering why would you loose the SRID information in this
process of calculating the centroid.
Thanks for all your help.
- kumar
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Paul Ramsey
Sent: Tuesday, September 20, 2005 7:31 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] mapserver-postgis centroid function
Matt is right, you should retrieve precisely as many columns as you
need, no more. A unique id, something to do labeling with, perhaps,
something to calculate classes with, perhaps, and the geometry
itself. That's it.
Paul
On Sep 20, 2005, at 2:44 PM, Matthew Perry wrote:
> David.
> On 9/20/05, David TECHER <davidtecher at yahoo.fr> wrote: I don't
> think so!
> Since Kumar wants to use a LABELITEM on 'PPIN'
> As a consequence, he should use '*'because PPIN
> should be a field in his table.
> Well * is what's causing the problems (redundant the_geom columns).
> How about replacing * with PPIN instead.
> Matt Perry
> perrygeo at gmail.com
> http://www.perrygeo.net
