Remote WMS layer
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Wed Sep 21 09:59:19 EDT 2005
If EPSG:9810 is a supported projection in your case (I do not have it in
my espg projection file), It should not make a diffrence when combining
wms layers and local. All of them are reproject to the projection
defined at the map file level.
BTW : you need to add a projection object on your layer. I don't
think that the wms_srs would be used for projection. Add something like :
PROJECTION
"init=epsg:9810"
END
Later,
Jørn Vegard Røsnes wrote:
> Thank you very much,
> it works!
> I guess I'm having some kind of combination problem. It's not working when
> adding this layer to you map-file.
> LAYER
> NAME coast
> TYPE LINE
> STATUS default
> DATA coast
> CLASS
> COLOR 10 10 10
> END
> METADATA
> WMS_TITLE "Coast"
> WMS_SRS "EPSG:9810"
> END
> END
> I remember that the WMS Client howto mentioned to be very aware of projections
> when combining WMS layer and other layers. I think this shapefile layer have
> data in polar stereographic (EPSG:9810?) projection.
> Any clues?
> Best Regards
> Joern
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
