routing
Paolo Cavallini
cavallini at FAUNALIA.IT
Wed Sep 21 13:03:25 EDT 2005
Thanks to all who responded. Quite reassuring to see that the solution I had
in mind are those you suggested.
I never used the pg module; is it possible to define only one start and end
point, or can I select multiple points?
I have cursorily read the README, but could not find it.
As Stephan pointed out, I would be inclined towards GRASS, but the database
approach seems more compact. Anybody has tried both methods, and can
arguments about respective merits?
Again, many thanks.
pc
At 12:40, mercoledì 21 settembre 2005, Norman Barker has probably written:
> -----Original Message-----
> Paolo,
> there is a brillant postgres extension called "pgdijkstra" from
> camp2camp. You need postgres 8.0. It delivers an algorythm for
> calculating the shortest path - you also may alter this by other
> attributes, because you are in the database.
> It's a horror to get the first data into the db (I can help) - if once
> done it is quite easy and afterwards it's easy to handle.
> Till
Paolo Cavallini
cavallini at faunalia.it cavallini at jabber.org www.faunalia.it
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
