routing
Till Adams adams at TERRESTRIS.DE
Thu Sep 22 03:31:03 EDT 2005
Paolo Cavallini wrote:
> Thanks to all who responded. Quite reassuring to see that the solution I had
> in mind are those you suggested.
> I never used the pg module; is it possible to define only one start and end
> point, or can I select multiple points?
> I have cursorily read the README, but could not find it.
> As Stephan pointed out, I would be inclined towards GRASS, but the database
> approach seems more compact. Anybody has tried both methods, and can
> arguments about respective merits?
> Again, many thanks.
> pc
> At 12:40, mercoledì 21 settembre 2005, Norman Barker has probably written:
>>-----Original Message-----
>>Paolo,
>>there is a brillant postgres extension called "pgdijkstra" from
>>camp2camp. You need postgres 8.0. It delivers an algorythm for
>>calculating the shortest path - you also may alter this by other
>>attributes, because you are in the database.
>>It's a horror to get the first data into the db (I can help) - if once
>>done it is quite easy and afterwards it's easy to handle.
>>Till
Dear Paolo,
no, I just trried the postgre method, but holl at gdf-hannover.de did this
with GRASS - ask him ;-)
Mit freundlichen Grüssen aus Bonn,
Till Adams
*  released: AmeiN! ArcMap-Export-2-UMN  *
*        LiveLinux 'WebGIS on CD'        *
*        http://www.terrestris.de        *
Dipl. Geogr. Till Adams
terrestris, H. Paulsen& T. Adams GbR
Siemensstr. 8 * 53121 Bonn
Tel.: 0228 962 899 52 * Fax.: 0228 962 899 57
info at terrestris.de * http://www.terrestris.de
