Remote WMS layer
Jørn Vegard Røsnes
jorn at SPACETEC.NO
Thu Sep 22 03:46:41 EDT 2005
Thanks,
adding PROJECTION (couldn't find EPSG code) and the hydro_data layer last in
the map file did the trick
LAYER
NAME coast
TYPE LINE
STATUS default
DATA coast
CLASS
COLOR 10 10 10
END
METADATA
WMS_TITLE "Coast"
END
PROJECTION
"proj=stere"
"lat_0=90"
"lon_0=0"
"lat_ts=60"
END
END
LAYER
NAME "hydro_data"
TYPE RASTER
STATUS ON
DEBUG ON
CONNECTION "http://dnweb5.dirnat.no:80/servlet/com.esri.wms.Esrimap?"
CONNECTIONTYPE WMS
METADATA
"wms_srs" "EPSG:32633"
"wms_name" "Vernet omrade,Vernet enkeltobjekt"
"wms_server_version" "1.1.0"
"wms_format" "image/png"
"wms_force_separate_request" "1"
END
END
On Wednesday 21 September 2005 15:59, Yewondwossen Assefa wrote:
> If EPSG:9810 is a supported projection in your case (I do not have it in
> my espg projection file), It should not make a diffrence when combining
> wms layers and local. All of them are reproject to the projection
> defined at the map file level.
> BTW : you need to add a projection object on your layer. I don't
> think that the wms_srs would be used for projection. Add something like :
> PROJECTION
> "init=epsg:9810"
> END
> Later,
> Jørn Vegard Røsnes wrote:
> > Thank you very much,
> > it works!
> > I guess I'm having some kind of combination problem. It's not working
> > when adding this layer to you map-file.
> > LAYER
> > NAME coast
> > TYPE LINE
> > STATUS default
> > DATA coast
> > CLASS
> > COLOR 10 10 10
> > END
> > METADATA
> > WMS_TITLE "Coast"
> > WMS_SRS "EPSG:9810"
> > END
> > END
> > I remember that the WMS Client howto mentioned to be very aware of
> > projections when combining WMS layer and other layers. I think this
> > shapefile layer have data in polar stereographic (EPSG:9810?) projection.
> > Any clues?
> > Best Regards
> > Joern
