Symbol rotation via attribute lookup
Richard Orth - osmoGIS Incorporated
rco at OSMOGIS.COM
Fri Sep 23 02:48:24 EDT 2005
Two things to try
1. Place a LABEL to display the value of 'heading'.
2. Check the attributes of the 'heading' field in PostGIS, is it a
string, integer, float, double, etc... ANGLEITEM may need to be a
non-string to work.
Hope this helps.
Richard C Orth
Michael Underwood wrote:
> Hello,
> I'm using PHP/MapScript 4.6 and trying to create a layer of points
> from a PostGIS database using an arrow pointing in the direction of
> the 'heading' field in the data table. No matter what I try though, I
> get a map with all of the arrows pointing straight up (i.e.
> unrotated). My definitions include a TrueType symbol using a
> character of an arrow pointing up (I've also tried drawing an arrow as
> a Vector symbol with the same results):
> SYMBOL
> NAME 'trackarrow'
> TYPE TRUETYPE
> FONT 'adings'
> FILLED false
> ANTIALIAS false
> CHARACTER 'a'
> END
> A layer with the following data source:
> DATA "vessel_coordinate from (select * from archive_v where
> vessel_id=12) as foo using unique myoid using SRID=-1"
> A class to size, colour and (in theory) rotate the symbol:
> CLASS
> SYMBOL 'trackarrow'
> SIZE 12
> STYLE
> COLOR 0 0 0
> ANGLEITEM 'heading'
> END
> END
> I know that the ANGLEITEM line is being read by MapServer because if I
> change the name in quotes I get an error that the field doesn't exist,
> and if I try putting the field name in square brackets I get parsing
> errors, but setup like this I simply get all of the arrows size
> twelve, coloured black, but pointing up. The table contains thousands
> of records with values in the heading field ranging from 0 to 359.
> Any insight into why the arrows won't rotate and how to make them do
> so would be greatly appreciated.
> Thanks,
> Mike
