WMS, convert GetCapabilites XML to Map Context XML
Armin Burger
armin.burger at GMX.NET
Sun Sep 25 15:14:23 EDT 2005
Tom,
thanks for the link. The Caps2Context.xsl is in fact for WMS. There seem
to be just some small discrepancies between the output of the template
and what the MapScript loadMapContext() function requires, but this
needs just slight modification of the XSL.
Armin
Kralidis,Tom [Burlington] wrote:
> The mapbuilder project (http://mapbuilder.sourceforge.net/) has a WFS
> Capabilities to WMC xsl in lib/tool/xsl/Caps2Context.xsl.
> There's one over at
> http://geoservices.cgdi.ca/mapbuilder/lib/tool/xsl/Caps2Context.xsl.
> You can probably modify it for WMS, and hopefully contribute it to the
> project!
> Cheers
> ..Tom
>>-----Original Message-----
>>From: UMN MapServer Users List
>>[mailto:MAPSERVER-USERS at lists.umn.edu] On Behalf Of Armin Burger
>>Sent: Saturday, 24 September, 2005 08:48
>>To: MAPSERVER-USERS at lists.umn.edu
>>Subject: [UMN_MAPSERVER-USERS] WMS, convert GetCapabilites
>>Hi everybody,
>>MapScript offers the nice functionality to add WMS layers via a Map
>>Context XML file.
>>I would like to convert the XML received from a
>>GetCapabilites request
>>into a Map Context XML document and load this Map Context XML file as
>>layers into the map object. I think XSL transformation could
>>be a good
>>solution to do this conversion. Has anybody already worked on an XSLT
>>template to convert the GetCapabilites XML into a Map Context
>>XML document?
>>Armin
