WCS multibands geotiff
Stepan Kafka stepan.kafka at CENTRUM.CZ
Mon Sep 26 03:31:05 EDT 2005
Hi all,
just for information...
I have discussed with Frank Warmerdam out of the list and these are the results:
It is able to get multispectral images with Mapserver WCS but We must take care for some parameters:
- the IMAGEMODE must be set to BYTE in the OUTPUTFORMAT object
- the ows_extent, wcs_resolution and wcs_bandcount metadata must be set  in layer metadata for tiled raster layers ( the ows_extent and wcs_resolution are not needed for single raster layer.)
- for tiled raster layers all filenames in tile layer must be valid (point to existing raster files) (there was my problem :) )
Thank  you, Frank
Stepan
______________________________________________________________
> Od: stepan.kafka at CENTRUM.CZ
> Komu: MAPSERVER-USERS at LISTS.UMN.EDU
> CC:
> Datum: 08.09.2005 08:44
> Předmět: [UMN_MAPSERVER-USERS] WCS multibands geotiff
> Hi all,
> I wonder if it is possible to get more than 4 bands geotiffs from WCS. I
> need to server all bands from Landsat images.
> Thank you
> Stepan Kafka
