problems with some Oracle polygons
Fernando Simon fsimon at UNIVALI.BR
Mon Sep 26 08:21:23 EDT 2005
Hi Francesco,
    I'm fine, your wecolme for your e-mail.
    This error appear when you use a type definition for your layer that
don't match for what Mapserver read from the source, for the problem
that relate probably Oracle Spatial driver reconize as a line segment.
Using the geometry definition that you sent I saw a problem, for
compound polygons (SDO_ETYPE 1005)  this definition it's wrong, the
first triplet indicates a SDO_GTYPE as 5, and this don't exist for
default Oracle Spatial parameter. I checked it in user guide (9i and
10g) and this SDO_TYPE don't appear in the table for SDO_ELEM_INFO.
    But exist a little information about this value for SDO_TYPE in the
SDO_ELEM_INFO chapter in the user guide, this section below I take from
user guide (10g):
            Note: The use of 5 as an SDO_ETYPE value for polygon ring
elements in a single geometry is discouraged. You should specify 5 only
if you do not know if the compound polygon is exterior or
interior, and you should then upgrade the table or layer to the current
format using the SDO_MIGRATE.TO_CURRENT procedure, described in Chapter 17.
    In this case I recommend that you test the SDO_MIGRATE function as
user guide suggested. Here I did a little test with  your data and after
apply the SDO_MIGRATE your geometry was draw correctly, you can check in
this link:
       After MIGRATE :
http://200.169.63.95/cgi-bin/map460?map=/home/apache/mapserv/maporaclespatial/maporaclespatial.map&mode=map&layer=99
       Before MIGRATE (as line):
http://200.169.63.95/cgi-bin/map460?map=/home/apache/mapserv/maporaclespatial/maporaclespatial.map&mode=map&layer=98_line
       Befor MIGRATE:
    After the MIGRATE function:
      SDO_GEOMETRY(2003, NULL, NULL, SDO_ELEM_INFO_ARRAY(1, 1005, 3, 1,
2, 1, 9, 2, 2, 17, 2, 1), SDO_ORDINATE_ARRAY(717393,311, 96290,2075,
717387,403, 96289,9591, 7
17352,296, 96287,4608, 717309,425, 96284,41, 717307,995, 96284,2265,
717305,79, 96283,6852, 717303,764, 96282,6628, 717301,79, 96281,1715,
717300,032, 96279,430 7, 717393,843, 96286,1065, 717393,311, 96290,2075))
   To execute the SDO_MIGRATE I did:
      SQL> execute sdo_migrate.to_current('cola_markets', 'shape');
    Best regards.
    Thanks again
Fernando Simon
Mapserver and Oracle Spatial developer
G10 - Laboratorio de Computacao Aplicada - Brazil
http://www.univali.br/g10 - UNIVALI/CTTMAR
Francesco Sozzi wrote:
> Hi Fernando,
> How are you?...
> In some cases I have polygon defined with a code "5" instead of
> "1005". In this case mapserver does not recognize the polygon format
> and it displayes an error:
> *Warning: [MapServer Error]: msDrawShape(): Only polygon shapes can be
> drawn using a POLYGON layer definition. in...*
> Here you are a sample polygon definition that gives me problems:
> SDO_GEOMETRY(2003, NULL, NULL, SDO_ELEM_INFO_ARRAY(1, 5, 3, 1, 2, 1,
> 5, 2, 2, 13, 2, 1), SDO_ORDINATE_ARRAY(717393.311, 96290.2075,
> 717393.843, 96286.1065, 717300.032, 96279.4307, 717301.79, 96281.1715,
> 717303.764, 96282.6628, 717305.79, 96283.6852, 717307.995, 96284.2265,
> 717309.425, 96284.41, 717352.296, 96287.4608, 717387.403, 96289.9591,
> 717393.311, 96290.2075))
> Any suggestions?...
> Best regards
> Francesco
