[Chameleon] Getting ready to do a red hat install
Matthew Edmondson matt0177 at GMAIL.COM
Wed Sep 28 14:14:20 EDT 2005
I would love to, but server admin wants to use his apache and php installs.
Would it be easier to download the fgs, and re-point everything to use the
install of apache and php, or would that be more trouble then its worth.
 The server is quad processor, with 32 gigs of ram and could very well be
hit hard with usage, so I want to make sure everything is as stable as
possible.
 Thanks,
 Matt
 On 9/28/05, Paul Spencer <pspencer at dmsolutions.ca> wrote:
> Matt,
> you could try fgs (http://www.maptools.org/fgs/)
> It is also possible (once you have fgs installed) to copy your ms4w/
> apps and ms4w/httpd.d folders to your linux box and add an include in
> the apache config to include all the httpd config files from ms4w.
> Then to make ms4w apps work out of the box, you only need to create
> an /ms4w/tmp and /ms4w/tmp/ms_tmp folder.
> Cheers
> Paul
> On 28-Sep-05, at 1:43 PM, Matthew Edmondson wrote:
> > I've been working on a mapserver/chameleon app for approx. 2 months
> > now. I've been working using a ms4w image on a win xp box. Now I'm
> > getting ready to deploy it on a server running red hat linux. Are
> > there sites/docs out there with a good general overview of
> > everything ill need and tips on the compiling.
> > With so many parts to my ms4w image (gdal,ogr,proj4 etc.) I'm sure
> > that I'll forgot a few things and run into a few problems, so
> > anything I could read before hand would be a great benefit.
> > Thanks,
> > Matt
> > Chameleon mailing list
> > Chameleon at lists.maptools.org
> > http://lists.maptools.org/mailman/listinfo/chameleon
> |Paul Spencer pspencer at dmsolutions.ca |
> |Applications & Software Development |
> |DM Solutions Group Inc http://www.dmsolutions.ca/|
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050928/78dafaed/attachment.html
