TILEINDEX and overviews (gdaladdo) ?
Frederic Claudel
fclaudel at CSIR.CO.ZA
Thu Sep 29 07:38:50 EDT 2005
Hi Manfred,
I think it's normal, and that viewing a footprint of 20km*20km will need to access around 400 files, then mosaic the overviews, which cannot be lightning speed.
I experienced the same slowdown when trying to open more than a dozen of file with overviews.
My solution is to create already mosaicked overviews, which I add as new layers into my mapfile. A minscale/maxscale helps choosing the correct layer.
Tell me if you need more details (maybe that approach is not what you're lokkin for)
cheers,
Frederic Claudel
>>> Manfred Zerndl <manfred.zerndl at BVV.BAYERN.DE> 29/09/2005 12:42 >>>
Does mapserver not take advantage of overviews calculated with
"gdaladdo" when
the files are accessed with TILEINDEX?
I have 77300 TIFF-Files. Each of them has 2500x2500 Pixels and each is
equivalent to one square kilometer
(Ground-resolution is 0.4 meters per pixel (1000 meters / 2500 pixels)).
(by the way, creating a Tile-Index with gdaltindex failed, becuase of
the amount of comand-line parameters.
So I generated a tileindex-Shapefile for my own, calculated each
bondingbox and used the tools "shpadd" and "dbfadd".)
For each of the 77300 TIFF-Files I generate overviews with the tool
"gdaladdo"
(for example: gdaladdo -r average file77300.tif 2 4 8 16 32 64 128)
Then I add the layer in the mapfile as following:
LAYER
NAME "DOP"
TILEINDEX "dop/dop.shp"
TILEITEM "LOCATION"
TYPE RASTER
STATUS ON
END
When I try with mapserver to view 200 meters with an image size of 500
Pixel,
the response is reasonably fast, because mapserver do not have to scale
the image
(the ground-resolution is 0.4 m/px).
But when I try to view 10 km or 20 km (kilometers) with an imagesize of
500 pixel,
mapserver take a very long time to answer (up to 1 Minutes).
Does mapserver not take advantage of the precalculated overviews in the
tiff-files generated with "gdaladdo"
when the files are accessed with TILEINDEX?
I have compiled mapserver on linux with --with-gdal and --without-tiff !!
$ mapserv -v
MapServer version 4.6.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=WCS_SERVER SUPPORTS=FASTCGI SUPPORTS=GEOS INPUT=EPPL7
INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Regards, Manfred
----- <start of additional infos> ---
Each of my TIFF-Files looks like this:
$ gdalinfo file77300.tif
Driver: GTiff/GeoTIFF
Size is 2500, 2500
Coordinate System is `'
Origin = (4467999.800000,5321000.200000)
Pixel Size = (0.40000000,-0.40000000)
Metadata:
TIFFTAG_XRESOLUTION=125
TIFFTAG_YRESOLUTION=125
TIFFTAG_RESOLUTIONUNIT=3 (pixels/cm)
Corner Coordinates:
Upper Left ( 4467999.800, 5321000.200)
Lower Left ( 4467999.800, 5320000.200)
Upper Right ( 4468999.800, 5321000.200)
Lower Right ( 4468999.800, 5320000.200)
Center ( 4468499.800, 5320500.200)
Band 1 Block=2500x1 Type=Byte, ColorInterp=Red
Overviews: 1250x1250, 625x625, 313x313, 157x157, 79x79, 40x40, 20x20
Band 2 Block=2500x1 Type=Byte, ColorInterp=Green
Band 3 Block=2500x1 Type=Byte, ColorInterp=Blue
The tool "tiffinfo" generates this:
TIFF Directory at offset 0x11e685a
Subfile Type: (0 = 0x0)
Image Width: 2500 Image Length: 2500
Resolution: 125, 125 pixels/cm
Bits/Sample: 8
Compression Scheme: None
Photometric Interpretation: RGB color
Orientation: row 0 top, col 0 lhs
Samples/Pixel: 3
Rows/Strip: 1
Planar Configuration: single image plane
TIFF Directory at offset 0x11e6920
Subfile Type: reduced-resolution image (1 = 0x1)
Image Width: 1250 Image Length: 1250
Tile Width: 128 Tile Length: 128
Bits/Sample: 8
Sample Format: unsigned integer
Samples/Pixel: 3
Planar Configuration: separate image planes
TIFF Directory at offset 0x11e732e
Image Width: 625 Image Length: 625
Bits/Sample: 8
Samples/Pixel: 3
TIFF Directory at offset 0x11e7634
Image Width: 313 Image Length: 313
Bits/Sample: 8
Samples/Pixel: 3
TIFF Directory at offset 0x11e77ba
Image Width: 157 Image Length: 157
Bits/Sample: 8
Samples/Pixel: 3
TIFF Directory at offset 0x11e78c8
Image Width: 79 Image Length: 79
Bits/Sample: 8
Samples/Pixel: 3
TIFF Directory at offset 0x11e798e
Image Width: 40 Image Length: 40
Bits/Sample: 8
Samples/Pixel: 3
TIFF Directory at offset 0x11e7a54
Image Width: 20 Image Length: 20
Bits/Sample: 8
Samples/Pixel: 3
----- <end of additional infos> -----
This message is subject to the CSIR's copyright, terms and conditions and
e-mail legal notice. Views expressed herein do not necessarily represent the
views of the CSIR.
CSIR E-mail Legal Notice
http://mail.csir.co.za/CSIR_eMail_Legal_Notice.html
CSIR Copyright, Terms and Conditions
http://mail.csir.co.za/CSIR_Copyright.html
For electronic copies of the CSIR Copyright, Terms and Conditions and the CSIR
Legal Notice send a blank message with REQUEST LEGAL in the subject line to
HelpDesk at csir.co.za.
This message has been scanned for viruses and dangerous content by MailScanner,
and is believed to be clean. MailScanner thanks Transtec Computers for their support.
