PHP/Mapscript 4.6.1 DSO causes Apache to segfault.
Toomas Aas
toomas.aas at RAAD.TARTU.EE
Thu Sep 29 08:24:12 EDT 2005
Hello!
I'm currently running the following software versions on FreeBSD 5.3
MapServer 4.2.5
PHP 4.3.10
PROJ 4.4.9
GDAL 1.2.1
GD 2.0.33
FreeType2 2.1.7
MapServer and PHP/Mapscript were configured with the following command:
./configure \
--with-freetype=/usr/local/bin/freetype-config \
--with-gd=/usr/local \
--with-eppl \
--with-proj=/usr/local \
--with-ogr=/usr/local/bin/gdal-config \
--with-gdal=/usr/local/bin/gdal-config \
--with-php=/usr/local/include/php
I have two instances of PHP on this machine - PHP CGI which is used for
Mapscript and mod_php which is used for everything else. PHP CGI is
configured with system regex and mod_php is configured with PHP's own
regex. Everything seems to be working fine.
I downloaded Mapserver 4.6.1 and ran exactly the same configure command,
followed by gmake. Adding the resulting php_mapscript.so to PHP
extensions causes Apache to segfault immediately on load. I tried to
read through the documentation and browse the list archives, but I can't
seem to figure out what I should do differently to produce a working
php_mapscript.so. The mapserv CGI, btw, works OK.
Toomas Aas --------------------------------------------------------
|arvutivõrgu peaspetsialist | head specialist on computer networks|
|Tartu Linnakantselei | Tartu City Office |
----------------------------------------------------- +372 736 1274
