groups and WMS
Yewondwossen Assefa assefa at DMSOLUTIONS.CA
Thu Sep 29 16:02:29 EDT 2005
Armin,
  In Mapserver if you have 2 wms layers that are in the same group you
should be able to do a GetMap request using he group name  but also on
the individual layers. You should not get an exception for trying to
fetch an individual layer belonging to a group.
Later,
Armin Burger wrote:
> Dear all,
> I have a question about the behaviour of groups in a WMS. When I define
> 2 layers belonging to the same group, I see both layers nested under the
> same group layer in the capabilities file.
> But I can only access the group as a WMS layer from a client. When I
> want to access the single layers belonging to that group I get an
> exception. That is in principal ok, but client programs might allow to
> select the single nested layers and the map will not be displayed
> because of the exception. Also the reason for grouping layers is quite
> often to have layers with different accuracy/resolution that should be
> swapped depending on the scale. So this should happen behind the scenes
> without the client noticing it.
> So my question is, why are the layers belonging to the same group
> displayed at all in the WMS capabilities if they cannot be used as
> single ones? Would it not make sense to just return the group as a WMS
> layer instead?
> Armin
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
