Map-file syntax for QuantaPlus, Kate, and Kwrite editors!
Walter Lorenzetti
walter at FAUNALIA.COM
Fri Sep 30 10:30:03 EDT 2005
i write xml file for implement quanta, kwrite and kate editors syntax!
With this file you can look your map file more easy!
Try it and send me a comment!
Walter
How to:
Take the file 'map.xml' at this url
http://www.faunalia.com/download/map.xml.tar.gz
and put it in one of this direcotry:
usr/share/apps/katepart/syntax
or in the
[home users] ~/.kde/share/apps/katepart/syntax
Here you can a small 'how-to' for kate sintax:
http://kate.kde.org/doc/hlhowto.php
Walter Lorenzetti
walter at faunalia.com www.faunalia.it www.faunalia.com
Via di Tofori 123 - 55010 Camigliano (LU), Italy Tel: (+39)347-6597931
Walter Lorenzetti
