GetFeatureInfo
Laura Díaz
laura.diaz at IVER.ES
Mon Apr 10 12:02:06 EDT 2006
just some points in mapserver documentation:
1. ext/html output using MapServer query templates specified in the CLASS template
parameter.
2. The MIME type returned by the Class templates defaults to text/html and can be
controlled using the metadata "wms_feature_info_mime_type"
3. Layer TEMPLATE (required for GetFeatureInfo requests)
4. Layer DUMP TRUE (only required for GetFeatureInfo GML requests)
5. You must set the layer TEMPLATE parameter for the layer to be queryable by
GetFeatureInfo requests. For requests of type "text/html" you should also set the layer
HEADER and FOOTER parameters. For GetFeatureInfo requests of GML you must set
the layer to DUMP TRUE in the mapfile. As of MapServer 4.6 you must also set the
gml_* metadata for the layer attributes to be served (see the Layer Object metadata in
the Reference Section later in this document).
an example that works for me:
LAYER
NAME obras
METADATA
"wms_title" "obras"
gml_include_items "all"
END
STATUS ON
TYPE POLYGON
DUMP TRUE
PROJECTION
"init=epsg:23030"
END
CONNECTIONTYPE postgis
CONNECTION
TOLERANCE 3
CLASS
NAME "obras"
TEMPLATE 'gmap/htdocs/templates/popplace.html'
COLOR 0 240 240
OUTLINECOLOR 199 199 199
END
END
regards,
Larua
On 10 Apr 2006 at 21:27, SUBSCRIBE MAPSERVER-USERS Joe wrote:
> Dear all,
> I set up my server as WMS Server. The problem is I could not query as html which
> I provide template, header and footer file.
> Is there anyone has an experience setting up WMS server for getfeatureinfo?
> I set up my map file as
> WEB
> IMAGEPATH "/data/maplab-2.2/tmp/"
> IMAGEURL "/maplab-2.2/tmp/"
> METADATA
> "wms_title" "INFO" ##required
> "wms_feature_info_mime_type" "text/html"
> "wms_onlineresource"
> "http://server.com/cgi-bin/mapserv?map=/data/maplab-2.2/AIT/info.map&"
> "wms_srs" "EPSG:42304 EPSG:42101 EPSG:4269 EPSG:4326" ##recommended
> END
> LAYER
> NAME TEST
> METADATA
> "wms_title" "TEST" ##required
> "wms_extent" "92.189278,5.610009,109.464638,29.180666"
> END
> TYPE POLYGON
> TRANSPARENCY 70
> DATA asia_bnd
> STATUS ON
> TEMPLATE asia.html
> END
> Thanks in advance,
> Thip
> This mail sent through AIT WebMail : http://www.ait.ac.th/
