Java Mapscript - querybyattribut SOLVED
Umberto Nicoletti umberto.nicoletti at GMAIL.COM
Tue Apr 18 09:11:39 EDT 2006
Please add the list to cc (reply to all) so that everybody can benefit
fro this ongoing discussion.
That said I think you need to check some things (I haven't a recipe
ready yet so we'll go by trial and error):
1)that you environment is correctly setup with regard to
internationalization (ie LANG and LC_* variables)
2) after that try to dump the content of the dbf file with dbfdump and
see that content is correctly displayed (you might want to use xterm
which does a better job that gnome-terminal for instance in displaying
non-ascii characters)
3) open the Java source file with an editor like gedit (from GNOME)
which will tell you the encoding of the java source and optionally
recode it to the same encoding set by the LANG variable (use the
recode command under linux).
Best regards,
Umberto
On 4/18/06, Nicol Hermann <nicol at nicol.info> wrote:
> Hi Umberto,
> as you suggested i compiled java mapscript with the option '-source
> 1.4'.
> Therefor i modified the JAVAC Variable in the Makefile to 'JAVAC=javac
> -source 1.4'.
> # Java Stuff
> JAVADOC=javadoc
> JAVAC=javac -source 1.4
> Attached you find the output of the compiling process [1].
> Sadly this modification did not change the situation when i query for:
> layer.queryByAttributes(map,"KREIS_NAME", "/Südliche Weinstraße/",
> mapscriptConstants.MS_MULTIPLE);
> in my test script.
> Did i miss one step to fix this issue?
> Many thanks for your assistance
> Nicol
> [1]
> nicol at emil:~/public_html/mapserver/sources/offical_releases/mapserver-4.8.1/mapscript/java$ make clean
> rm -rf examples/*.class
> nicol at emil:~/public_html/mapserver/sources/offical_releases/mapserver-4.8.1/mapscript/java$ make interface
> mkdir -p edu/umn/gis/mapscript
> swig -java -package edu.umn.gis.mapscript -o
> mapscript_wrap.c ../mapscript.i
> mv *.java edu/umn/gis/mapscript/
> gcc -fpic -c -g -O2 -fPIC -Wall  -DENABLE_STDERR_DEBUG
> -DNEED_NONBLOCKING_STDERR -DIGNORE_MISSING_DATA -DHAVE_VSNPRINTF
> -DNEED_STRLCAT  -DUSE_EPPL -DUSE_PROJ -DUSE_WMS_SVR -DUSE_WMS_LYR
> -DUSE_WFS_SVR -DUSE_WFS_LYR -DUSE_MING_FLASH -DUSE_ORACLESPATIAL
> -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT
> -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS  -DUSE_SDE -DUSE_OGR
> -DUSE_GDAL -DUSE_POSTGIS    -I/usr/local/include  -I/usr/local/include
> -I/usr/local/sdeexe83/include   -I/usr/local/include
> -I/usr/local/pgsql_8/include
> -I/home/oracle/product/10.1.0/client/rdbms/demo
> -I/home/oracle/product/10.1.0/client/rdbms/public
> -I/usr/local/j2sdk1.4.2_08/include
> -I/usr/local/j2sdk1.4.2_08/include/linux -fno-strict-aliasing
> mapscript_wrap.c
> gcc -fpic -shared mapscript_wrap.o -o libmapscript.so  -L../.. -lmap
> -lgd -L/usr/local/lib -lgd -ljpeg -lfreetype -lpng -lz    -ljpeg
> -lfreetype -lpng -lz   -L/usr/local/lib -lproj -ljpeg
> -L/usr/local/sdeexe83/lib -lsde83 -lpe83 -lsg83 -lpthread -ldl
> -L/usr/local/lib -lgdal -lming -L/usr/local/pgsql_8/lib -lpq  -L/usr/lib
> -lcurl -lidn -lssl -lcrypto -ldl -lssl -lcrypto -ldl -lz
> -L/home/oracle/product/10.1.0/client/lib -lclntsh   -lm -lstdc++
> javac -source 1.4 edu/umn/gis/mapscript/*.java
> jar cf mapscript.jar edu
> Am Freitag, den 14.04.2006, 15:23 +0200 schrieb Umberto Nicoletti:
> > Olivier,
> > I GOT IT!
> > try to run the attached Java source. If you pass it two arguments the
> > first being the path to the map file and the second the string to
> > search for and you pass
> > "Südliche Weinstraße" as the second it will work!
> > So why does it fail when "Südliche Weinstraße" is inside the Java
> > code? That is a problem that only happens when javac compiles the
> > source: javac translates all characters to unicode and in doing that
> > it gets the german characters wrong.
> > To solve this give javac the following option: -source 1.4
> > For more see this link:
> > http://bugs.sun.com/bugdatabase/view_bug.do?bug_id=5046139
> > On 4/13/06, Umberto Nicoletti <umberto.nicoletti at gmail.com> wrote:
> > > This is probably not related only to java mapscript, so please read on.
> > So I was wrong...but I'll leave the proof to the reader ;-)
> > Best regards,
> > Umberto
> > > On 3/30/06, Oliver Wesp <wesp at gdv.com> wrote:
> > > > Dear List,
> > > > I' struggling with queryByAttributes on an attribute field with german
> > > > umlauts using java mapscript.
> > > > The odd thing is that the same thing works fine with php mapscript and
> > > > when I use expressions in my  mapfile. I'm using a shapefile as datasource.
> > > Could someone of the other mapserver developers shed some light on this issue?
> > > I have a clue to give: php mapscript is using a different regex
> > > library and this explains why the match does not happen for Java
> > > mapscript, while it does happen in php mapscript. If I am right also
> > > the mapserver cgi should be affected and possibly all other mapscript
> > > too.
> > > It would be very interesting if someone could report on similar
> > > experiences with the cgi-bin version of mapserver.
> > > Thanks,
> > > Umberto
> > > > Here is what I do:
> > > > layer.open();
> > > > System.out.println( "Result Count: " +layer.getNumResults() );
> > > > layer.close();
> > > > The result is always null while replacing the qstring with something
> > > > that doesn't contain special characters (e.g.
> > > > 'Mainz-Bingen') works fine.
> > > > As noted above the following layer definition in a mapfile works fine
> > > > LAYER
> > > >      NAME kreis
> > > >      STATUS DEFAULT
> > > >      TYPE polygon
> > > >      DATA "/tmp/subset"
> > > >      TEMPLATE "kreis.html"
> > > >      CLASSITEM KREIS_NAME
> > > >      CLASS
> > > >        NAME Boundary
> > > >        COLOR 128 128 0
> > > >        OUTLINECOLOR 0 0 0
> > > >        EXPRESSION /Südliche Weinstraße/
> > > >      END
> > > > END
> > > > but this does not:
> > > > layer.setClassitem("KREIS_NAME");
> > > > classObj cl = new classObj(layer);
> > > > cl.setName("Classname");
> > > > cl.setExpression("/Südliche Weinstraße/");
> > > > I use Mapserver 4.8.1 on W2k, Tomcat 5.0.28.
> > > > I can provide some sample data, just in case someone likes to reproduce.
> > > > Any help is appreciated.
> > > > best regards
> > > > Oliver
> > > > Dipl.-Geogr. Oliver Wesp
> > > > Gesellschaft fuer geografische Datenverarbeitung
> > > > Binger Strasse 49-51
> > > > D-55218 Ingelheim
> > > > fon: +49 6132 714818
> > > > fax: +49 6132 714828
> > > > http: www.gdv.com
