[ka-Map-users] Color shifts using QUANTIZE_COLORS=256
Stephen Woodbridge woodbri at SWOODBRIDGE.COM
Wed Aug 9 17:56:09 EDT 2006
Paul Spencer wrote:
> Steve,
> I concluded the same thing you did (that the colours are mangled).
> FrankW had an explanation for this that I didn't really understand.  He
> suggested that providing a mechanism to specify a fixed colour table
> would be the real answer.
> Tile sizes in my experiments were 50% smaller in most cases (using
> quantization).
> Dithering had no observable effect on the colour problem, but did result
> in crappy looking images in most cases (hence I suggested turning it off).
> ImageMagick is able to produce outstanding 8bit pngs from 24bit
> antialiased images, so it is possible.
So have you guys done anything along the line of integrating ImageMagick
  with mapserver? How did you do your testing with ImageMagick? It seems
that most of my tiles are close enough in color that it is not
noticeable, but every now and then there is a very noticeable difference.
> I would love to see something in mapserver that kept track of all the
> colours that were allocated in the various styles and rendering stages,
> and from the headers of the raster symbols, and used that as the colour
> table when doing quantization or whatever is needed.
> As a minimum, it should be possible to specify a COLORS block or
> something at the MAP level that would force those colours into the
> output image.  This would actually solve a long standing issue with 8
> bit images and raster symbols where antialiased text uses all the
> colours and then the raster symbol colours get mangled.
Yeah, it seems we should do something like this. We have been struggling
with color shift issues for a few years now. We fix one and another pops up.
Do you have any thoughts on using ImageMagick vs AGG? It seems that AGG
would produce better images in general. I wonder if it does antialiasing
directly into an 8-bit image which I would think would give you much
better control.
-Steve
> My 2c
> Paul
> On 9-Aug-06, at 1:56 PM, Stephen Woodbridge wrote:
>> Hi all,
>> Sorry for the cross-post, but this seems valid for both groups.
>> I have mapserver configured to work with ka-map and things are working
>> fine except we have noticed color shifts in tiles. We are using:
>>   OUTPUTFORMAT
>>     NAME PNG8
>>     DRIVER "GD/PNG"
>>     EXTENSION "png"
>>     MIMETYPE "image/png"
>>     IMAGEMODE RGBA
>>     TRANSPARENT OFF
>>     FORMATOPTION "QUANTIZE_FORCE=ON"
>>     FORMATOPTION "QUANTIZE_DITHER=OFF"
>>     FORMATOPTION "QUANTIZE_COLORS=256"
>>   END
>> in our mapfile and my hypotheses is that the GD QUANTIZE process is
>> selecting different colors based on the colors available in the various
>> meta-tiles. The mapserver source code calls the following function for
>> this process and from the GD manual:
>>> void gdImageTrueColorToPalette(gdImagePtr im, int ditherFlag, int
>>> colorsWanted) gdImagePtr gdImageCreatePaletteFromTrueColor(gdImagePtr
>>> im, int ditherFlag, int colorsWanted) (FUNCTION)
>>> gdImageCreatePaletteFromTrueColor returns a new image.
>>> gdImageTrueColorToPalette permanently converts the existing image.
>>> The two functions are otherwise identical.
>>> The function converts a truecolor image to a palette-based image,
>>> using a high-quality two-pass quantization routine. If ditherFlag is
>>> set, the image will be dithered to approximate colors better, at the
>>> expense of some obvious "speckling." colorsWanted can be anything up
>>> to 256. If the original source image includes photographic
>>> information or anything that came out of a JPEG, 256 is strongly
>>> recommended. 100% transparency of a single transparent color in the
>>> original truecolor image will be preserved. There is no other support
>>> for preservation of alpha channel or transparency in the destination
>>> image.
>>> For best results, don't use this function -- write real truecolor
>>> PNGs and JPEGs. The disk space gain of conversion to palette is not
>>> great (for small images it can be negative) and the quality loss is
>>> ugly. However, the version of this function included in version
>>> 2.0.12 and later does do a better job than the version included prior
>>> to 2.0.12.
>> So, a few questions:
>> 1) Has anyone looked into the impact of using PNG24 images on
>>   a) image sizes
>>   b) ka-map tile-cache sizing
>>   c) compatibility with browsers
>>   d) impact on browser memory usage or performance
>> 2) I thought Paul Spencer said to use DITHERED=OFF, is this correct
>> 3) Has anyone looked at the GD routine? Would it be possible to add a
>> palette of say 32 colors that would be "sticky" and priority over
>> other colors?
>> -SteveW
>> ka-Map-users mailing list
>> ka-Map-users at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/ka-map-users
> |Paul Spencer                           pspencer at dmsolutions.ca   |
> |Applications & Software Development                              |
> |DM Solutions Group Inc                 http://www.dmsolutions.ca/|
