storing lat/long coordinates as points
    Stephen Woodbridge
    woodbri at SWOODBRIDGE.COM
    Tue Aug 15 18:09:17 PDT 2006
Ryan Ollerenshaw wrote:
> does anyone know how to store lat/long coordinates in PostgreSQL as POINTS?
Assuming you have PostGIS installed, you might try:
select AddGeometryColumn('schema_name', 'table_name', 'the_geom', 4326,
'POINT', 2);
the_geom = the column
4326 = SRID for WGS84
'POINT' = Geometry type
2 = the dimension of the point ie (X,Y)
then you can do this:
insert into schema_name.table_name (the_geom) values
(setsrid(makepoint(long, lat), 4326));
-Steve
More information about the MapServer-users
