class intervals etc
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Thu Aug 24 17:53:33 EDT 2006
2 - See the class TEXT parameter in mapfile reference guide. It allows
simple
formating.
3 - several possiblities, although usually it's because either the
EXTENT or SIZE
values in your reference object are wrong.
4 - that's a client issue, you need to detect the size of the browser
window and use
that to compute a size to pass to mapserver (via mapsize if you use the
CGI). There
are probably tons of discussions about how to do this reliably
accessible via google.
6 - see
http://mapserver.gis.umn.edu/docs/reference/templatereference/templatereference#zoom
Steve
>>> siva <volunteer at SPATIALLINK.ORG> 8/23/2006 3:03:28 PM >>>
ok i ask my questions again
1 i make thematic map using shapefile dbf. but i got 28 states. do i
color every state differently or is color 'random range' possible??
when user sees map, he want to create class intervals. how i recolor
map from url input dynamically??
2 how i add text to label?? i label points as 1, 2, 3 from shapefile
dbf. how to label as project 1, project 2, projet 3??
3 my reference img box does not match my map img??
4 how to make map img seze = 75% of page area or 1.75 em??
5 my symbol size does not work right?? i use symbols35.sym
6 how to make radio zoom value remembered by mapserver??
sincerely
sshekar
