map.removeLayer(index) -- C#
Tamas Szekeres szekerest at GMAIL.COM
Mon Aug 28 10:02:40 EDT 2006
Zhonghai,
There was problem with insertLayer according to
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1838
The problem was recently fixed (4.10.0-beta1 should contain the fix).
Is the removeLayer problem also exist for the other layers? (not for
the dynamically added layers)
Which mapserver version are you using?
Could you include a code sample according to the problem?
Tamas
2006/8/28, Zhonghai Wang <zhonghaiw at gmail.com>:
> Hi guys,
> I am trying to remove an inline feature using the map.removeLayer(index),
> but it seems that this method does not work. The inline feature layer is
> created on the fly, not in the mapfile hard coded. Does anyone ever used
> this function successfully? There may also be some problems with the
> map.insertLayer(layerObj, index), only map.insertLayer(layerObj,-1) works
> for me, I can not specify the index.
> thanks for any hints to solve my problem.
> Zhonghai
