Using join for querying
cris ricana crisricana at GMAIL.COM
Tue Aug 29 04:32:54 EDT 2006
Hello!
I'd like some help regarding my use of JOIN in my mapserver setup. I'm
using two sets of data, a base shapefile ("reg_bndary") containing
basically place information and system-generated csv files containing
all the relevant information regarding these places in the shapefiles.
Both have a common field called Place_ID to be used for the join. I
was planning to use these csv in times when the users want to query
for detailed information on these places. My map file looks like this
(the JOIN part is near the end):
NAME reg_bndary2000.map
SIZE 600 600
EXTENT 114.03 3.8315 131.33 21.1585
SHAPEPATH "data"
IMAGETYPE PNG
UNITS meters
WEB
  TEMPLATE 'reg_bndary2000.html'
#  IMAGEPATH '/home/mis/DIRP/maps/'
#  IMAGEURL 'home/mis/DIRP/maps/'
  IMAGEPATH '/home/yronald/htdocs/maps/test_map/maps/'
  IMAGEURL '/test_map/maps/'
END  #WEB
QUERYMAP
  SIZE 600 600
  STATUS ON
  STYLE SELECTED
  COLOR 255 0 0
END
  LAYER
  NAME CY_2000
  TYPE polygon
  STATUS ON
  DATA reg_bndary
  CLASSITEM COUNT
  LABELITEM REGION
     CLASS
        NAME "443 - 688"
        EXPRESSION ([COUNT]>=443 AND [COUNT]<=688)
        COLOR 205 0 0
        OUTLINECOLOR 0 0 0
          LABEL
            COLOR 0 0 255
            SIZE LARGE
          END
        TEMPLATE "reg_bndary2000_dbf.html"
     END  # CLASS
     CLASS
        NAME "226 - 442"
        EXPRESSION ([COUNT]>=226 AND [COUNT]<=442)
        COLOR 255 193 193
        OUTLINECOLOR 0 0 0
          LABEL
            COLOR 0 0 255
            SIZE LARGE
          END
     END  # CLASS
     CLASS
        NAME "106 - 225"
        EXPRESSION ([COUNT]>=106 AND [COUNT]<=225)
        COLOR 154 255 154
        OUTLINECOLOR 0 0 0
          LABEL
            COLOR 0 0 0
            SIZE LARGE
          END
     END  # CLASS
     CLASS
        NAME "0 - 105"
        EXPRESSION ([COUNT]>=0  AND [COUNT]<=105)
        COLOR 0 100 0
        OUTLINECOLOR 0 0 0
          LABEL
            COLOR 0 0 0
            SIZE LARGE
          END
     END  # CLASS
     CLASS
        NAME "No Data"
        EXPRESSION ([COUNT]="")
        COLOR 255 255 255
        OUTLINECOLOR 0 0 0
          LABEL
            COLOR 0 0 0
            SIZE LARGE
          END
     END  # CLASS
     HEADER "reg_bndary2000_header.html"
     FOOTER "reg_bndary2000_footer.html"
     JOIN
        NAME "reg_join"
        CONNECTIONTYPE CSV
        TABLE "lgu_DB_DACCESS_PROV.csv"
        FROM "Place_ID"
        TO "1"
        TEMPLATE "reg_bndary 2000_dbf.html"
     END #join
END  # LAYER
END  # MAPFILE
The template file used for , "reg_bndary 2000_dbf.html", contains
simply the following:
[reg_join_REGION]<br>
[reg_join_PLACE]
When when I test this, I get the following error:
       msQueryByPoint(): Search returned no results. No matching
record(s) found.
Can somebody help me tell me what is wrong in my setup?
Thanks!
Maricris
