Problems with WFS and OracleSpatial
Fernando Simon
fsimon at UNIVALI.BR
Mon Dec 4 05:33:07 EST 2006
Looking for the log that you past appeared a strange problem.
You defined you layer data with the USING UNIQUE parameter, but the
OBJECTID don't appear in the Apache log. This is the log for the request
to a layer that uses UNIQUE? The oraclespatial driver don't execute any
query function without the UNIQUE parameter in your data layer.
Best regards.
Fernando Simon
José Ramón López wrote:
> Im trying to configure a WFS Server with oraclespatial.
> This is the definition of the layer:
> LAYER
> NAME ferrocarriles
> TYPE line
> CONNECTIONTYPE oraclespatial
> CONNECTION "user/pass at SDE "
> DATA "SHAPE FROM RED_FERROCARRIL USING UNIQUE OBJECTID VERSION 9i"
> DUMP TRUE
> DEBUG ON
> TRANSPARENCY 0
> PROJECTION
> "init=epsg:23030"
> END
> CLASS
> NAME 'Red Ferrocarriles'
> COLOR 255 0 255
> END
> METADATA
> "wms_title" "Red Ferrocarriles"
> "wms_abstract" "Red Ferrocarriles"
> "wms_keywordlist" "WMS Red Ferrocarriles"
> "wfs_title" "Red Ferrocarriles"
> "gml_featureid" "OBJECTID"
> "gml_include_item" "all"
> END
> END
> When i make a getcapabilities like:
> http://192.168.53.18:81/cgi-bin/mapserver?SERVICE=WFS&VERSION=1.1.1&REQUEST=Getcapabilities
> <http://192.168.53.18:81/cgi-bin/mapserver?SERVICE=WFS&VERSION=1.1.1&REQUEST=Getcapabilities>
> it shows me
> <FeatureType>
> <Name>ferrocarriles</Name>
> <Title>ferrocarriles</Title>
> <SRS>EPSG:4326</SRS>
> <LatLongBoundingBox minx="195210" miny="4.07581e+006" maxx="533545"
> maxy="4.26175e+006"/>
> </FeatureType>
> But if i make a getfeature:
> http://192.168.53.18:81/cgi-bin/mapserver?service=WFS&version=1.0.0&request=getfeature&typename=ferrocarriles
> <http://192.168.53.18:81/cgi-bin/mapserver?service=WFS&version=1.0.0&request=getfeature&typename=ferrocarriles>
> <wfs:FeatureCollection xsi:schemaLocation="http://www.opengis.net/wfs
> http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd
> <http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd>
> http://mapserver.gis.umn.edu/mapserver
> http://localhost:81/cgi-bin/mapserver?service=WFS&SERVICE=WFS&VERSION=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=ferrocarriles&OUTPUTFORMAT=XMLSCHEMA
> <http://localhost:81/cgi-bin/mapserver?service=WFS&SERVICE=WFS&VERSION=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=ferrocarriles&OUTPUTFORMAT=XMLSCHEMA>">
> <gml:boundedBy>
> <gml:Box srsName="EPSG:4326">
> <gml:coordinates>
> 195210.088989,4075810.305023 533545.363841,4261747.980489
> </gml:coordinates>
> </gml:Box>
> </gml:boundedBy>
> </wfs:FeatureCollection>
> With some clients, like udig or gvsig i can connect to wfs, but i cant
> get info.
> In apache´s error.log
> [error] msOracleSpatialLayerOpen called with: SHAPE FROM
> RED_FERROCARRIL\r
> [error] msOracleSpatialLayerOpen. Shared connection not available.
> Creating one.\r
> [error] msConnPoolRegister(ferrocarrile
> s,user/pass at SDE,0173D7E0)\r
> [error] msOracleSpatialLayerFreeItemInfo was called.\r
> [error] msOracleSpatialLayerWhichShapes was called.\r
> [error] msOracleSpatialLayerWhichShapes. Using this Sql to retrieve
> the data: SELECT rownum, SHAPE FROM RED_FERROCARRIL WHERE SDO_FILTER(
> SHAPE, MDSYS.SDO_GEOMETRY(2003, NULL,
> NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),
> MDSYS.SDO_ORDINATE_ARRAY(195210,4075810,533545,4261747)
> ),'querytype=window') = 'TRUE'\r
> [error] msOracleSpatialLayerClose was called. Layer connection:
> user/pass at SDE \r
> [error] msOracleSpatialLayerClose. Cleaning layerinfo handlers.\r
> [error] msOracleSpatialLayerClose. Cleaning Oracle handlers.\r
> [error] msConnPoolRelease(ferrocarriles,user/pass at SDE,0173D7E0)\r
> [error] msConnPoolClose( user/pass at SDE,0173D7E0)\r
> [error] msOracleSpatialLayerOpen called with: SHAPE FROM RED_FERROCARRIL\r
> Creating one.\r
> [error] msConnPoolRegister(ferrocarriles, user/pass at SDE,0179A3F0)\r
> [error] msOracleSpatialLayerGetItems was called.\r
> [error] msOracleSpatialLayerInitItemInfo was called.\r
> [error] msOracleSpatialLayerGetShape was called. Using the record = 1.\r
> user/pass at SDE\r
> [error] msConnPoolRelease(ferrocarriles,user/pass at SDE,0179A3F0)\r
> [error] msConnPoolClose(user/pass at SDE,0179A3F0)\r
> Does anybody know what is happening?
> Thanxs
> José Ramón López
> Tfno: 627 88 88 24
