TIFF rendering suffering in quality
John B. Churchill
jchurchill at AL.UMCES.EDU
Tue Dec 5 08:36:38 EST 2006
On Mon, December 4, 2006 3:37 pm, Frank Warmerdam wrote:
> John B. Churchill wrote:
>> Hi,
>> I'm new to the list and also very new to MAPSERVER. Please bear
>> with me. I've started a map by replacing the ITASCA DEMO data with my
>> own data. I'm having some trouble getting a DOQQ tif (true color) image
>> to display a reasonable image. I've been reading about using the
>> OUTPUTFORMAT tag to tweek the way the output image looks (e.g. 24-bit).
>> Can anyone help me figure out how I can best display this TIFF format
>> image.
>> See My Description of the problem and my CODE here:
>> http://alx.al.umces.edu/~jchurch/GIS/tif_render.html
> John,
> Put the:
> IMAGETYPE JPEG
> keyword in your MAP section. The OUTPUTFORMAT declaration you provided
> has no effect unless you select the format, but for web purposes you
> likely
> don't want to be returning geotiffs, so just select JPEG or PNG24 - the
> two
> common 24bit image formats for the web.
THANKS ... that worked. The IMAGETYPE was set to PNG. When I changed it
to JPEG it looked great.
