error compiling on OpenSUSE 10.1
Thom DeCarlo
t.r.decarlo at LARC.NASA.GOV
Tue Dec 5 10:06:04 EST 2006
I did a work-around by commenting out the "#ifndef YY_CURRENT_BUFFER_LVALUE"
test in maplexer.c. That allowed the compile to finish. I also had to add
the GRASS libraries to the link stage, since my gdal was compiled with GRASS
support and the mapserver build was failing due to missing GRASS libraries.
Now that it has compiled, I'm on to the next step... setting up the web
server.
Thom
> -----Original Message-----
> From: Thom DeCarlo
> Sent: Monday, December 04, 2006 3:52 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] error compiling on OpenSUSE 10.1
> I seem to be having the same problem that came up back in May. (Jens
> Dahnken: compiling error mapserver 4.2 under SLES 9) I didn't find any
> resolution in the archive, so maybe he just gave up.
> I am compiling mapserver from the current cvs.
> When the compile gets to shp2img, I am getting an undefined reference to
> 'msyylineno' in libmap.a(mapfile.c). The only suggestions I found to solve
> the problem was to install flex and bison. I have flex 2.5.31-16 and bison
> 2.1-11 installed.
> The comments in maplexer.c suggest that the test used to figure out if
> flex
> 2.5.31 may have problems. Since I am certain that I've got the right
> version
> of bison, should I just force the test to true?
> Thom
> this sig intentionally left blank
