loadProjection(): Unknown identifier error
Matthew Edmondson
matt0177 at GMAIL.COM
Tue Dec 5 16:11:58 EST 2006
I've been utilizing mapserver for over a year now, mainly utilizing
chameleon. I downloaded the latest ms4w install and have been messing
around with ka-map. I've been using a modified .map file of the world
map and have run into a snag.
If I insert the line
PROJECTION "init=EPSG:4326"
into my map file, the file wont load via html, and via mws it gives
the error of "loadProjection(): Unknown identifier error" If I comment
out that line, it works fine. I'm trying to get this to work, beacuse
otherwise I'm running into trying to access the data via mws from
other applications.
Thanks,
Matt
p.s. I'm attaching the world file.
MAP
NAME "LAT LONG"
STATUS ON
EXTENT -113.275 30.908 -108.751 33.924
SIZE 600 300
SYMBOLSET ../etc/symbols.sym
SHAPEPATH "../data"
UNITS DD
IMAGECOLOR 200 200 200
INTERLACE ON
IMAGETYPE png24
OUTPUTFORMAT
NAME jpeg
DRIVER "GD/JPEG"
IMAGEMODE RGB
EXTENSION "jpeg"
FORMATOPTION "QUALITY=60,PROGRESSIVE=TRUE"
END
WEB
METADATA
max_extents "-113.275,30.908,-108.751,33.924"
END
END
REFERENCE
IMAGE "../data/TCA_reference.png"
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
SIZE 250 125
END
LEGEND
OUTLINECOLOR 0 0 0
STATUS on
KEYSIZE 40 10
KEYSPACING 20 15
TRANSPARENT on
END
SCALEBAR
STATUS ON
IMAGECOLOR 255 255 255
COLOR 0 0 0
OUTLINECOLOR 0 0 0
LABEL
COLOR 0 0 0
SIZE tiny
END
UNITS miles
STYLE 1
INTERVALS 5
TRANSPARENT ON
SIZE 249 15
END
#LAYER
# NAME "World"
# STATUS off
# METADATA
# imageformat "PNG"
# END
# transparency 55
# DATA "countries_simpl.shp"
# TYPE POLYGON
#CLASSITEM "cat"
#CLASS
# NAME "Country"
#EXPRESSION /./
#STYLE
# OUTLINECOLOR 100 100 100
#COLOR 200 170 170
#END
#END
#END # layer
#LAYER
# NAME "Label"
# STATUS off
# METADATA
# imageformat "PNG"
# END
# TYPE ANNOTATION
# LABELITEM 'name'
# CLASS
#LABEL
# PARTIALS false
# MINDISTANCE 250
# MINFEATURESIZE 40
# POSITION CC
# COLOR 255 255 255
# OUTLINECOLOR 0 0 0
# SIZE tiny
# ANTIALIAS TRUE
# BUFFER 4
# END
#END
#END #layer
LAYER
NAME az_30m_ned
TYPE RASTER
STATUS on
DATA "tca_NED_image1.tif"
METADATA
"ows_title" "TCA 30M AOR Dem"
"ows_srs" "EPSG:4326"
END
END # Layer
LAYER
NAME "Airports"
STATUS ON
TYPE POINT
DATA "airprtx020.shp"
LABELITEM 'name'
CLASS
NAME "Airports"
STYLE
SYMBOL "star"
SIZE 8
COLOR 0 0 0
END
END
END # Layer
LAYER
NAME roads
TYPE LINE
STATUS on
DATA "az_sec_hwys.shp"
labelitem "HIGHWAY_NM"
CLASS
name 'Roads'
size 20
COLOR 0 0 0
END
METADATA
"wms_title" "Roads"
"wms_srs" "EPSG:4326"
END
END # layer
END
