loadProjection(): Unknown identifier error
Andy Freed
afreed at PDX.EDU
Tue Dec 5 16:24:08 EST 2006
Try adding an END after the projection:
PROJECTION
"init=epsg:4326"
END
Andy
Matthew Edmondson wrote:
> I've been utilizing mapserver for over a year now, mainly utilizing
> chameleon. I downloaded the latest ms4w install and have been messing
> around with ka-map. I've been using a modified .map file of the world
> map and have run into a snag.
> If I insert the line
> PROJECTION "init=EPSG:4326"
> into my map file, the file wont load via html, and via mws it gives
> the error of "loadProjection(): Unknown identifier error" If I comment
> out that line, it works fine. I'm trying to get this to work, beacuse
> otherwise I'm running into trying to access the data via mws from
> other applications.
> Thanks,
> Matt
