Line-end geometry?
Fawcett, David David.Fawcett at STATE.MN.US
Wed Dec 6 14:14:19 EST 2006
Is the line geometry significant, or are you really just drawing
line-arrow symbols at point locations?
If it is the latter case, you could create a point shapefile and then
label the points with an existing (or one that you create) TrueType font
character that is a line with an arrow tip.  Use LABELANGLEITEM to point
the arrow in the right direction.
David.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Jeff Dege
Sent: Wednesday, December 06, 2006 12:47 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Line-end geometry?
I have a layer with line data.
I want to draw the lines with arrow-heads at one end.
The data represents short line segments that point at certain locations
- my customer wants them to draw like little arrows.
What's the easiest way of doing this?  (Recognizing that I can't modify
the underlying data.)
