Resubmit Question: ms4w, variable substitution,
mapfile EXTENT object attr
Matt Pettis
matt.pettis at THOMSON.COM
Wed Dec 6 14:46:31 EST 2006
line 8 is the 'SIZE' line i've included... i'll dig it up
From: Fawcett, David [mailto:David.Fawcett at state.mn.us]
Sent: Wednesday, December 06, 2006 1:10 PM
To: Pettis, Matthew (TLR Corp); MAPSERVER-USERS at lists.umn.edu
Subject: RE: [UMN_MAPSERVER-USERS] Resubmit Question: ms4w, variable
substitution, mapfile EXTENT object attr
Matt,
Can you post the text of your map file? What is in line 8?
David.
-----Original Message-----
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Matt Pettis
Sent: Wednesday, December 06, 2006 12:37 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Resubmit Question: ms4w, variable
No one answered this question, so I am resubmitting:
I am trying to write a mapfile that will use javascript to
dynamically sent EXTENT values to a .map file via POST parms.
Concretely, when I select a county in MN from a dropdown, I want to send
the appropriate values for the EXTENT bbox so that the selected county
is rendered in it's specific bbox.
The beginning of my mapfile looks like this:
MAP
IMAGETYPE PNG
EXTENT %xmin% "%ymin%" "%xmax%" "%ymax%"
SIZE 880 660
the url i issue is:
http://localhost/cgi-bin/mapserv.exe?map=C%3A%5Cms4w%5CApache%5Chtdocs%5
Ctest_postgis2%5CDynSQL_ByCounty%5Cmap.map&map_web_imagepath=C%3A%5Cms4w
%5CApache%5Chtdocs%5Ctmp%5C&mode=map&xmin=439430.71875&ymin=4959166&xmax
=486045.78125&ymax=5010473.5&coid=27
<http://localhost/cgi-bin/mapserv.exe?map=C%3A%5Cms4w%5CApache%5Chtdocs%
5Ctest_postgis2%5CDynSQL_ByCounty%5Cmap.map&map_web_imagepath=C%3A%5Cms4
w%5CApache%5Chtdocs%5Ctmp%5C&mode=map&xmin=439430.71875&ymin=4959166&xma
x=486045.78125&ymax=5010473.5&coid=27>
the error i get is:
getDouble(): Symbol definition error. Parsing error near
(%):(line 7)
line 7 is the EXTENT line.
So, my questions are:
1. Does MapServer support variable substitition for extent
values? If so, what am i doing wrong? If not, how do I dynamically set
the extent for dynamically selected polygons with different bboxes?
2. Is there a better way to set the bbox rather than send it
precalculated values in a GET? It seems natural that I should be able to
leave the EXTENT line off and a default of the smallest bounding box
that works for the returned geometry would be returned as a default.
tia,
Matt
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061206/be9e6a6c/attachment.html
