optimization
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Wed Dec 6 22:25:42 EST 2006
boice tomlin wrote:
> Hi Steve,
> I've rebuilt mapserver with the debug option and copied the
> new php_mapscript.so over.
> And I've added the debug option in the map file as well.
> no luck.
> I see this in my configure log.
> configure:10254: checking whether we should enable debug features...
> configure:10271: result: Enabling debug features: -g in CFLAGS
> and msDebug() to stderr (-DENABLE_STDERR_DEBUG).
> I checked all of my PHP and apache logs and don't see anything. Do you
> see anything I missed?
I have never tried the DEBUG stuff with php/mapscript, so I'll have to
defer to others on that, but I would expect it to work
In the mapfile I have
MAP
NAME "test"
DEBUG ON
I then watch:
sudo tail -f /var/log/apache/error.log
and I hit a url like, (I would use the saved mapfile from your php run)
http://localhost/cgi-bin/mapserv?mode=map&map=/path/to/mapfile.map&mapxy=<long>+<lat>&scale=<scale>&map_size=300+200
Works for me every time.
-Steve W
> thanks,
> boice
>> 2) build mapserver with the debug option in ./configure
>> then add DEBUG TRUE to the map section of you mapfile
>> then render you map and look in /var/log/apache/error.log
>> and you will fine information about how long it takes each layer
>> to render. do this at the various scales you use.
>> if you have huge shapefiles and you are only rendering parts of them
>> then consider using shape2tile to break the data into tiles.
>> 3) optimize the slow layers
>> a) reduce the amount of data you are displaying
>> maybe turn off that layer at that scale
>> create a generalize version of that layer for that scale
>> b) reduce the number of labels if you label cache time is large
>> turn off some of the labels you are drawing at that scale
>> 4) if it is a raster layer that is slow, then post a message asking
>> Frank Warmerdam or Ed McNierney for suggestions on how to improve
>> your reaster performance
>> 5) if I haven't covered it here or you are sure what to do about a
>> specific performance issue, post a more specific question.
>> 6) oh yeah, if you are using shapefiles and have problems rendering
>> data mvoing to postgres will generally not help you.
>> -Steve W
>> boice tomlin wrote:
>>> Hello users,
>>> The map located here;
>>> http://gisinventory.net/status_maps.html
>>> takes a while to load. At least at the national view where there is
>>> a lot of area to render.
>>> I am looking for alternative ways to generate the map that will
>>> significantly improve performance.
>>> Currently I am using php and looping through data and turning on
>>> layers as I go. The PHP part is lightning fast. But after I get the
>>> map ready mapserver takes several seconds to generate it.
>>> I'm curious about alternative ways to handle this problem and wonder
>>> if anyone had comments on any of them.
>>> 1) modifying the shape files in some way so the layer information is
>>> in those files.
>>> 2) using a db such as postgres with postgis.
>>> Right now I have to generate a bunch of dynamic classes in PHP using
>>> the general method below.
>>> $lyr = $this->ramona_map->getLayerByName("state_yes");
>>> $cla = $lyr->getClass(0);
>>> $cla->setExpression("/".$expression."/");
>>> $lyr->set("status", MS_ON);
>>> I have to do this several hundred times to represent all of the
>>> data. The time it takes to generate the map seem proportionate to
>>> the amount of layers I make visible. And again this is on the
>>> mapserver side and not PHP. PHP does its part of the operation in
>>> thousandths of a second.
>>> thanks,
>>> -boice tomlin
>>> Run Skip
>>> http://runskip.com <http://runskip.com/> /
>>> boice tomlin
>>> boice at runskip.com <mailto:boice at runskip.com>
>>> 503-528-6204
>>> Run Skip
>>> http://runskip.com/
>>> boice tomlin
>>> 503-528-6204
> Run Skip
> http://runskip.com/
> boice tomlin
> 503-528-6204
