Long generation time of map images in mapserver
Thomas Shaw mapserv at UBICALO.COM.MX
Thu Dec 7 10:58:56 EST 2006
Hello Hal and List;
Thank you for your answer
As you told me I haven't had the projection tag in the mapfile.
Unfortunatelly I have tried setting the projection:
PROJECTION
  "proj=latlong"
  "ellps=WGS84"
  "datum=WGS84"
END
that is the one that all the maps have, and I didn't noticed a better
performance. What other issue could be happening?
Thank you in advance
> Is there any chance that you have omitted the ellipsoid in your
> projection definition?
> I had several mapfiles without it.  They worked fine on 4.2, but
> sometimes were very slow on 4.6.  When I went to 4.10 I started
> seeing the error message at
> http://mapserver.gis.umn.edu/docs/error/axis-radius .  Interestingly
> though, I didn't see it every time.  I could reload the exact same
> map, and sometimes it would throw the error, sometimes not.
> Once I fixed that, the slow rendering maps got fast again.
> At 2:39 PM -0500 12/6/06, Thomas Shaw wrote:
>>Hello List!
>>I have actually installed mapserver-4.8.4 & PHP5 (as a dynamic library of
>>mapscript) in my production server and I'm experiencing some strange
>>behavior (that I haven't had with the 4.2 version) with the mapserver
>>generation time of the images maps. Sometimes I zoom in/out and the image
>>generations take less than a second, but also some other times the
>>generation takes about 12 seconds. Firstly I thought that it was the
>>internet connection, but I tried it also over the LAN and it had the same
>>strange behavior. So what could be possible happening?
>>When I changed from mapserver 4.2 to 4.8.4 I didn't modified any
>> parameter
>>of value in the mapscript, and in the mapfile.
