mapObj.zoomRectangle from Java Mapscript.
Javier Caicedo
jcaicedo at CTI.ESPOL.EDU.EC
Thu Dec 7 15:00:54 EST 2006
According to the Mapscript API mapObj.zoomRectangle first parameter must
be in image coordinates, so you should set the last parameter of the
rectObj constructor to TRUE. Here goes an example from my current project:
//vMap is an instance of mapObj
rectObj rect = vMap.getExtent(); //map coordinates
String [] box = getCurrentRequest().getParameter("box").split(" ");
//box is something like this: 10 10 200 200
//0,0 is at top left, so box defines top left and bottom right corners
double mx = Double.parseDouble(box[0]);
double my = Double.parseDouble(box[1]);
double mxx = Double.parseDouble(box[2]);
double mxy = Double.parseDouble(box[3]);
//bunch of validation code ommitted
rectObj rbox = new rectObj(mx,mxy,mxx,my,mapscriptConstants.MS_TRUE);
//notice the switch of mxy and my
//rectObj constructor requires you define bottom left and top right
//corners. rbox is in image coordinates
vMap.zoomRectangle(rbox,w,h,rect,null);
Hopefully this will help you out a little.
Regards,
Javier Caicedo Espinoza
CTI - ESPOL
Guayaquil, Ecuador
