Expression so slow ...
Paul james
pauljame at GMAIL.COM
Fri Dec 8 07:30:46 EST 2006
Hello again...
The problem is not the expressions ... I took off them and the problem
continue ....
I believe is a problem with my sql :
_layer.data = "the_geom from (select count(def.descproblem) as number,
def.descproblem, tg.city, lm.geocode, lm.the_geom from tblTower tg
inner join tblInsp on (tg.numgeraltower = i2.numgeraltower and tg.idlt =
i2.idlt)
inner join tblProblens def on ( i2.idproblem = def.idproblem and i2.idlt =
def.idlt)
inner join limit_city lm on (upper(lm.name) = upper(tg.city) and upper(
lm.uf) = upper(tg.estate))
where def.descproblem = 'PROBLEM DETECTED' and i2.datemanutencao BETWEEN
'2005-01-01' AND '2006-11-30'
group by def.descproblem, tg.city, lm.geocode, lm.the_geom
order by number) as thematic using unique geocode using srid=-1";
Any idea?
----- Original Message -----
*To:* MAPSERVER-USERS at LISTS.UMN.EDU
*Sent:* Thursday, December 07, 2006 4:21 PM
*Subject:* [UMN_MAPSERVER-USERS] Expression so slow ...
Hello guys!
I´m creating a POLYGON layer in mapscript (c#) with a lot of classes like
that :
layerObj _layer = new layerObj(mapaObj);
_layer.classitem = "geocode";
while (_reader.Read())
_geo = Convert.ToInt32(_reader["geocode"]);
_city = _reader["city"].ToString();
classObj _class = new classObj(_layer);
_class.name = __city;
_class.template = "dummy";
_class.setExpression(_geo.ToString());
styleObj _style = new styleObj(_class);
_style.color.setRGB(_num.Next(0, 255), _num.Next(0, 255),
_num.Next(0, 255));
All works great, so I got a Themathic map (very fast - about 2secs)
The problem occurs when I started to aproximate to one new POLYGON (Zoomin).
Each zoom took more and more time (about 8-10secs) to draw the map. Its very
strange...
Did I miss anything?
ps.: I´m using Mapserver 4.10, windows xp and C#
[]´s
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061208/e7257274/attachment.html
