map performance
boice tomlin
boice at RUNSKIP.COM
Fri Dec 8 15:45:21 EST 2006
Steve,
Reduced resolution datasets are the trick.... I just increased
performance 10 fold by substituting a reduced polygon shapefile.
thanks for your help on both fronts.
-boice
On Dec 6, 2006, at 12:33 PM, Steve Lime wrote:
> It would help to see the mapfile generated. From the looks of your
> application it looks like you should only need 4 classes, and only 3
> with expressions (the fourth being the default). I also wouldn't
> expect
> you needing to use regex but that depends on the data. I don't know a
> ton about your data but this doesn't seem like an instance where
> PostGIS
> would add much. Using reduced resolution datasets can definitely help
> big time, especially with the city and county datasets. For cities you
> could even consider using points since almost every polygon would
> loose
> it's shape at the national level (e.g. 2x2 square).
> Steve
>>>> boice tomlin <boice at RUNSKIP.COM> 12/6/2006 10:55:52 AM >>>
> Hi Steve,
> Assuming I was using static class items. Do you think my method of
> using a regular expression to specify which geographies to display
> is a
> good method?
> Thanks for the tip on saving the map file. Very cool. It looks as I
> expected or at least hoped. Basically my original map file with a few
> extra classes and regular expressions for the layers I display.
> Someone else suggested a method using postgis that would pull in shape
> data with less polygons for certain extents.
> Couldn't I use a version of the shape files I have now with less
> detail/polygons when rendering a map at larger extents?
> I actually want to explore every method I can for optimization. My
> goal is a fairly descriptive national view in 1 tenth of a second. Is
> that too lofty?
> thanks,
> boice
> On Dec 5, 2006, at 6:32 PM, Steve Lime wrote:
> Might be interesting to see what the resulting mapfile (after your
> dynamic work) looks like (use $map->save(...)).
> We'd really need to know more about the data, how you're doing
> classifications and such to comment more. There may be lots of ways
> to make things go faster. From the looks of it for each geography
> (city, county, tribe, state, nation) you have a bunch of variables
> that
> indicate
> if a data theme is available. One could organize that data like so
> (for
> example state level data):
> State Hydrography Watersheds ...
> MN 0 1
> WI 3 2
> IA 3 0
> FL 1 3
> Where 0 means no responce, 1 complete and so on. So in that case your
> class definitions would always be the same you'd
> be simply changing the variable you're mapping on (e.g. CLASSITEM),
> and
> you wouldn't need dynamic classes (or even MapScript for that
> matter). Just thinking out loud...
> Steve
> boice tomlin <boice at RUNSKIP.COM> 12/4/2006 1:24:58 PM >>>
> Hello users,
> The map located here;
> http://gisinventory.net/status_maps.html
> takes a while to load. At least at the national view where there is a
> lot of area to render.
> I am looking for alternative ways to generate the map that will
> significantly improve performance.
> Currently I am using php and looping through data and turning on
> layers
> as I go. The PHP part is lightning fast. But after I get the map
> ready
> mapserver takes several seconds to generate it.
> I'm curious about alternative ways to handle this problem and wonder
> if
> anyone had comments on any of them.
> 1) modifying the shape files in some way so the layer information is
> in
> those files so that all mapserver has to do is load those files and
> not
> depend on the map files.
> 2) using a db such as postgres with postgis so that layer information
> is available all in one compact source.
> Right now I have to generate a bunch of dynamic classes in PHP using
> the general method below.
> $lyr = $this->ramona_map->getLayerByName("state_yes");
> $cla = $lyr->getClass(0);
> $cla->setExpression("/".$expression."/");
> $lyr->set("status", MS_ON);
> I have to do this several hundred times to represent all of the data.
> The time it takes to generate the map seem proportionate to the amount
> of layers I make visible. And again this is on the mapserver side and
> not PHP. PHP does its part of the operation in thousandths of a
> second.
> anyone's thoughts are greatly appreciated.
> -boice tomlin
> Run Skip
> http://runskip.com/
> boice tomlin
> boice at runskip.com
> 503-528-6204
> Run Skip
> http://runskip.com/
> boice tomlin
> 503-528-6204
Run Skip
http://runskip.com/
boice tomlin
503-528-6204
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061208/ee95481d/attachment.html
