AW: [UMN_MAPSERVER-USERS] a mapserver framework for flexibility
Arnd Wippermann arndw at WTAL.DE
Sat Dec 9 09:14:38 EST 2006
Hello list,
Using OpenLayers I have build a map client for WMS and Mapserver requests.
It supports to add and delete servers on the fly, set the visibility of
layers, change the order of display, GetFeatureInfo, Styled Layer
Descriptors (SLD), change the projection (no reprojection), set opacity
(only Firefox).
It is thought as an locally used client, easy to configure for own data and
display them with external WMS layers. I use popup windows for the map
controls, so i don't need to reduce the size of the map display. It is
poorly programmed in javascript, but it works.
I hope someone have a look.
With Openlayers Version 1.0 :
http://gis.ibbeck.de/ginfo/ibbOLClient/OpenLayersClient.html
And with Version 2.2 : http://gis.ibbeck.de/ginfo/ibbOLClient/olc2.2.html
Arnd Wippermann
http://gis.ibbeck.de/ginfo/index.html
-----Ursprüngliche Nachricht-----
Von: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] Im
Auftrag von P Kishor
Gesendet: Freitag, 8. Dezember 2006 23:48
An: MAPSERVER-USERS at LISTS.UMN.EDU
Betreff: Re: [UMN_MAPSERVER-USERS] a mapserver framework for flexibility
On 12/8/06, Ed McNierney <ed at topozone.com> wrote:
> Puneet -
> Or, the more likely risk that safari advertisements will start
> appearing on your maps of Kenya <g>.
very funny, and very bloody likely.
> Alternatives are good, but please keep in mind that Google's API is
> really not an option for many commercial sites.  Depending on your
> point of view, that's either irrelevant or a fatal obstacle!
yes, absolutely correct. I did not bring into account the Terms of Service
(TOS) of Google Maps. Since I am not making any commercial sites (for now at
least), frankly I have only skimmed through the TOS.
Read them carefully and use at your own risk.
My consideration was purely on its technical merit -- letting Google do all
the legwork in making sure the darn thing works with different browsers and
other such useless nonsense that most web application developers end up
wasting their lives on.
Nevertheless, yes, alternatives are always good... and a few months down the
road, there will be yet another email asking for which framework is better,
and we will have even more choices. (I miss those emails asking for which
language was best for MapServer development -- we don't get those anymore --
I guess PHP on MS-Win  decimated all
choices)
> > From: P Kishor <punkish at EIDESIS.ORG>
> > Reply-To: P Kishor <punkish at EIDESIS.ORG>
> > Date: Fri, 8 Dec 2006 15:01:32 -0600
> > To: <MAPSERVER-USERS at LISTS.UMN.EDU>
> > Subject: Re: [UMN_MAPSERVER-USERS] a mapserver framework for
> > flexibility
> > I would like to submit an alternative MapServer framework -- it is
> > called Google Maps. I have been putting together an application, the
> > very alpha version of which can be seen at
> > <http://ecoservices.eidesis.org>
> > The stuff on my webserver, aka the "backend", is Perl and SQLite
> > using the most excellent CGI::Application framework for creating
> > websites, the geodata other than Google's maps, aka the "sideend",
> > is our beloved MapServer, and the interface, aka the "frontend", is
> > Google's MAP API.
> > There is a rich set of tools and techniques published for public
> > consumption, and for the most part, Google does the hard work for me
> > creating all this so I don't have to re-invent the wheel. In the
> > best example of laziness, I just choose and put it all together.
> > The MapServer works with the least of embellishments and accoutremets.
> > It just serves data as WMS services using pure CGI.
> > Of course, one downside is that Google could go belly-up tomorrow
> > and its mapping services would be shut down. I can live with that risk.
> > On 12/8/06, Neil Best <nbest at forestone.com> wrote:
> >> Hi, Bob.  Thanks for your note.  The choice of authentication is
> >> wide open at this point.  We just need to have basic user/password
> >> functions and some concept of groups so that access to data can be
> >> controlled by organization.  Why do you ask?
> >> I have not looked at Mambo.  Have you?  Tell me about your project.
> >> Is there anything online I can check out?
> >> Creation and maintenance of the layers is crucial, but would be
> >> handled internally so the interface would not need to be as slick
> >> as that presented to customers.  I believe that Mapbender, for
> >> example, uses OGC services exclusvely but assumes that those services
are all set up, i.e.
> >> no features for creating those layers AFAICT, which is okay.  We
> >> could set them up by hand at first and eventually build a back-end app,
perhaps.
> >> Neil
> >> Bob Basques wrote:
> >>> Neil,
> >>> Can you describe more of the authentication process you would like to
use.
> >>> Are you planning on implementing the Authentication in the Mambo
> >>> environment?
> >>> I have a new project that might fit your bill.  But alas there's
> >>> not much documentation put together for it yet.
> >>> The layer aspects are all configured separately.  Each layer is
> >>> managed separately by it's respective owner and accessed
> >>> separately by the Client.  The General idea was to place control
> >>> and upkeep of the data in the hands of the data creators and not
> >>> bother the system admins with work related to updating and maintaining
the datasets.
> >>> bobb
> >>> Neil Best wrote:
> >>>> [ I encountered some of kind of glitch while trying to submit
> >>>> this through the web interface, that's why the empty item from
> >>>> me.  I wanted to include an old item that aligned  well with my
> >>>> agenda and that seemed like the obvious way, but I ended up doing
> >>>> it with good old cut and paste after all. ]
> >>>> Eduardo, I found your note to mapserver-users while searching the
> >>>> archive for any sign that others have been down this path before.
> >>>> That was some time ago and I'm not sure I can do a good job of
> >>>> finding other related threads since then, but what you describe
> >>>> sounds very similar to the task that I have recently taken on, to
> >>>> find a web mapping framework based on open source tools that
> >>>> maximizes leverage of existing code while providing
> >>>> extensibility, maintainability, and scalability.  This
> >>>> application will provide access to specific data subsets and
> >>>> analysis tools under a subscription model to a diverse group of
> >>>> users so by definition user profiles will drive the content and
> >>>> client-side tools presented by the application.  This entails far
> >>>> more than just slapping together some layers and putting a map on
> >>>> the web, plus it needs to happen *fast* so building a web site
> >>>> from scratch is not an option.  To these ends I will be
> >>>> evaluating a small set of packages after conducting a brief survey of
Mapserver-based projects in general, including but not limited to:
> >>>> Cartoweb     http://www.cartoweb.org/
> >>>> Mapbender    http://www.mapbender.org/
> >>>> PrimaGIS     http://www.primagis.fi/
> >>>> I have been studying these projects in web space and have started
> >>>> evaluating them in user/admin space and have already begun to
> >>>> form my own opinions and impressions.  It would be great to hear
> >>>> from members of the community who have insight into these issues
> >>>> and learn from their experiences.  Maintainers and contributors
> >>>> to whichever
> >>>> framework(s) meet my basic needs while demonstrating that
> >>>> additional features can be developed rapidly and efficiently can
> >>>> expect to hear from me in the near future soliciting proposals
> >>>> for a range of services from client-side functionality to
> >>>> back-end integration and management of data services, development
> >>>> efforts that could and should make their way back to the code
> >>>> base of their respective projects.  If you are still reading then you
must be interested, so drop me a line!
> >>>> Whether on- or off-list is up to you, but any comments at all are
> >>>> welcome.  My employer is very serious about this so I earnestly
> >>>> hope that this will generate some traffic and enthusiasm.
> >>>> Sincerely,
> >>>> Forest One, Inc.
> >>>> http://www.forestone.com/
> >>>> On Sun, 21 Aug 2005 21:45:11 -0300, Eduardo Patto Kanegae
> >>>> <lists at WEBMAPIT.COM.BR> wrote:
> >>>>> Hi folks,
> >>>>> I'm currently looking for a MapServer *framework* to build
> >>>>> MapScript applications inside another application : MamboServer.
> >>>>> Just to clarify, MamboServer ( www.mamboserver.com ) is a free
> >>>>> CMS software written in PHP and have a lot of great features.
> >>>>> Now, we want to integrate MapServer inside Mambo as a mambo
component.
> >>>>> I was thinking to use Chameleon as preffered mapping framework,
> >>>>> but is my suggestion right?
> >>>>> Can I  do it? Or chameleon can just work alone? I mean, can I
> >>>>> use Chameleon widgets to load MapFiles, draw maps but inside
> >>>>> another PHP application? ( because, we need to validate user
> >>>>> rights, etc...)
> >>>>> another idea I was thinking about is to develop OGC maps, to be
> >>>>> used with desktop applications (JUMP,uDig,ArcGIS OGC,...) and
> >>>>> also a set of "mirror" maps  using NON-ogc access , to be used
> >>>>> by PHP/MapScript applications. I was thinking in doing things
> >>>>> this way to get some "speed" on web applications. But, is this
> >>>>> really necessary? Or OGC maps should be enough to feed web
> >>>>> MapServer clients and desktop clients?
> >>>>> thanks in advance.
> >>>>> best regards.
> > Puneet Kishor http://punkish.eidesis.org/ Nelson Inst. for Env.
> > Studies, UW-Madison http://www.nelson.wisc.edu/ Open Source
> > Geospatial Foundation https://edu.osgeo.org/
> > collaborate, communicate, compete
Puneet Kishor http://punkish.eidesis.org/ Nelson Inst. for Env. Studies,
UW-Madison http://www.nelson.wisc.edu/ Open Source Geospatial Foundation
