Problems with mapserver and oblique projections
Frank Warmerdam
warmerdam at POBOX.COM
Sat Dec 9 23:55:04 EST 2006
Steve Roberts wrote:
> Adding the following code to the subroutine msProjectRect
> in mapproject.c just before the line "if( failure > 0 )" would do the
> trick:
Steve,
Would you mind submitting this as a bugzilla bug report, ideally along
with a small map+dataset demonstrating the problem. Something I could
include in the test suite (ie. < 30K of data or so).
I'm concerned that the patch may do undesirable things in some cases,
but I'd like to put it in place. However, given the risks, I want to
keep a good "documentation and test" trail for the changes.
Note that msReprojectRect() is used for things other than just search
rectangles for features, so the -180 to 180 problem across the dateline
could be even serious than false positives in the search sometimes.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
